darstcreek77
Member since April 2011
Post by darstcreek77 on Aug 14, 2011 7:27:27 GMT -5
The saw blades I have bought are crap I need asaw blade that will last past three cuts. Any info would be great I have a 10 inch saw As I am new to this trial and error is getting expensive lol .... thanks Allen
Post by jakesrocks on Aug 14, 2011 7:35:52 GMT -5
darstcreek77
Post by darstcreek77 on Aug 14, 2011 8:50:47 GMT -5
how many cuts do you get (roughly) I guess it depends on rock hard nest , thanks of the info I will contact him .
Post by jakesrocks on Aug 14, 2011 9:21:14 GMT -5
A bunch. I've been using a 16" BD303 for the last 3 months. Been cutting really hard agate, and the blade hasn't had to be dressed yet. As soon as the blade on my 10" starts to wear out, I plan on ordering a couple of BD 303's for it too. Don
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Aug 14, 2011 9:50:07 GMT -5
OK, what do you mean that 'the blade hasn't had to be dressed yet?' I am fairly new and have not heard this before, at least that I recall any way.
Thanks so much,
Tammy
Post by jakesrocks on Aug 14, 2011 10:02:05 GMT -5
With use, a blade will start to get dull. The surface diamonds have broken down and been covered with metal from the rim of the blade. To dress the blade, you can make a few cuts through a piece of obsidian, cinder block or an old silicon carbide grinding wheel. This removes the metal and exposes new diamond. It's possible that your old blades need to be dressed, and may continue cutting for a while longer. If you have a piece of inexpensive black obsidian, try making 2 or 3 cuts through it, then try cutting a piece of hard agate. Don
brent
Member since November 2008
Post by brent on Aug 14, 2011 11:55:51 GMT -5
What kind of blade do you have now?
darstcreek77
Post by darstcreek77 on Aug 14, 2011 12:06:31 GMT -5
just plain old cinder block will dress a blade ?
Post by jakesrocks on Aug 14, 2011 12:19:32 GMT -5
Yes. Just make a few cuts through an old broken cinder block. It should cut easy, even with a dull blade.
Post by Sabre52 on Aug 14, 2011 12:52:41 GMT -5
Yeah, I've been using a 303 for cutting hard pet wood and agate for several months now and it shows almost no wear at all. Makes very smooth cuts too. It's a very good blade.....Mel
juzwuz
Member since April 2010
Post by juzwuz on Aug 15, 2011 0:59:27 GMT -5
