riverrock
Member since April 2010
Post by riverrock on Sept 7, 2011 10:42:41 GMT -5
Have a issue with Labradorite wont take a shine. Went through all stages and no contamination in the polish. Don,t know if i should go back into the 500 grit to try again. unless someone else could give me better advice. Thanks in advanced
Post by tandl on Sept 7, 2011 16:44:54 GMT -5
the tutorial above says cerium oxide is best, for lab .
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Sept 7, 2011 18:03:04 GMT -5
The Rock Shed suggests 1000 grit AO between the pre-polish and the polish stages for lab and other softer stones. I've even read of using 1500 grit SiC between the pre-polsh and polish stages for some stones.
Post by Jack ( Yorkshire) on Sept 8, 2011 1:15:15 GMT -5
A lot depends on the quility of the rock as well
I have tried to get a good shine on some low grade stuff and end up with a dull sample ful of cracks , when dry, but when wet it looks fantastic
jack Yorkshire uk
riverrock
Post by riverrock on Sept 8, 2011 18:55:05 GMT -5
Thanks for the replys. Jack the stones might be low grade they are full of fine cracks. I will try the 1000 for kicks.
Post by Jack ( Yorkshire) on Sept 12, 2011 2:50:22 GMT -5
Hi riverrock,
I Have coated my low grade with Epoxy which gives a fair result have a go with that after you try 1000 G
Jack Yorkshire uk
