shermlock
Member since August 2011
Post by shermlock on Nov 17, 2011 20:40:52 GMT -5
My hose is frozen and my hands are too. How do you folks who live in the north clean your tumbles in between grits? Thanks, Scott
grayfingers
Member since November 2007
Post by grayfingers on Nov 17, 2011 20:51:54 GMT -5
I use 2, 5 gal buckets. I set a wire strainer that fits on the top of a bucket, dump the load into it. I put water in the 2nd bucket, dump part of it over the rocks in the strainer in bucket # 1. Then stir the rocks and dump a bit more water over them.
Continue until they are pretty well washed off. I then put more water in the 2nd bucket and dump the rocks into it for a final rinse. Finally pour off the water into the 1st bucket, take it outside and slowly dump it so any remaining grit settles into the bottom. Then I dry that out, and reuse it.
P.S. I start by dumping some water into the empty barrel, scrub it out and dump that over the rocks in the strainer a time or two and then proceed as described above.
Bill
Post by jakesrocks on Nov 17, 2011 22:42:31 GMT -5
I do my cleanups indoors on the breakfast counter. I lift the rocks out of the tumbler barrel into a 5 quart ice cream bucket which is about 1/3 full of water. When all of the rocks are out of the barrel I dump the mud and grit in a 5 gallon bucket to dry. I wash just the rim of the barrel and put the rocks back in with water to just cover them, and a heaping tablespoon of borax. I tumble again for about an hour and then lift the rocks back into an ice cream bucket of warm water. The borax tumble makes barrel cleanup quick and easy. I move the rocks into a fresh bucket of water. After 3 or 4 times doing this the water in the ice cream bucket is clear, and the rocks ready for the next tumble stage.
Post by Rockhobbit on Nov 17, 2011 23:27:47 GMT -5
Most of them drive or fly to Arizona for the winter! LMAO!!
Post by Jack ( Yorkshire) on Nov 18, 2011 3:03:12 GMT -5
Washing rocks I Run of the thick goop put a few drops washing up liquid in barrell and add water run for a few minuits
Turn out onto a wire bottomed tray run water over them , they are clean in a jiffy ! !
This reduces the time and agony of working in the cold
jack Yorkshire uk
Post by quartz on Nov 18, 2011 21:19:02 GMT -5
Granted, I suit up for the cold, but the washing goes pretty well. I built a 5-foot long, countertop high workbench {on wheels and steerable} with a stainless steel double kitchen sink set in it. This sets under the edge of our covered patio, and I run a hose from the utility room so as to have warm water. Our average run nets out at about 45 pounds, so this would be a little difficult inside. The water and washings go out to a settling tank, then to an underground perforated drain pipe.
