algonquin
Member since October 2011
Post by algonquin on Nov 21, 2011 15:02:24 GMT -5
I've collected Unakite from Lake Superior which has been rounded by the waves and was wondering seeing as I have the shape I want already, can I skip Step 1 of a tumbling phase and jump in #2 or should I just start from the beginning?
Post by tntmom on Nov 21, 2011 15:22:06 GMT -5
If it doesn't have any pits you should be fine. 220 will not remove pits though.
keystonecops
Member since October 2010
Post by keystonecops on Nov 21, 2011 19:40:49 GMT -5
A lot of the beach rock I gather goes right into med, long as its not pitted. Should be about the same deal. Later Clyde
Post by johnjsgems on Nov 21, 2011 19:44:19 GMT -5
I used to tumble a lot of beach rocks and found at least a short run (like 3-5 days or maybe a week) in 60/90 was beneficial. You usually have deep scratches that show up later and it helps to clean and remove any organic material.
Post by Toad on Nov 21, 2011 23:14:06 GMT -5
I'm with John. A week in 60/90 won't hurt anything and might be very beneficial.
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Nov 22, 2011 1:32:10 GMT -5
I have collected and tumbled Unakite from Lake Superior myself. I have found some ready for the medium grit, but it seems the feldspar and epidote erode differently, so the water "smoothed" stones actually have an orange peel texture if you look closely. I usually tumble them in 60/90 for at least a short time.
algonquin
Post by algonquin on Nov 22, 2011 12:51:04 GMT -5
Excellent - thank you for the vice
