Post by BuiltonRock on Dec 8, 2011 17:00:16 GMT -5
I was home with a sick boy today and while he slept I was busy. This is a Buck 110 with Actinolite from Tandl (Ted). This is a metamorphic rock that is a bit soft, but without fractures and has a better shine than the pictures show. Not too bad for a first try. The only problem is the blade does not snap back as good as it should. Any help is appreciated. Thanks for looking! John
Post by tandl on Dec 8, 2011 17:36:18 GMT -5
John , You done a great job , for it being your first one . Looks Great !
firewalker45
Member since August 2006
Post by firewalker45 on Dec 8, 2011 17:44:07 GMT -5
Looking good! Daniel
Post by rockmanken on Dec 8, 2011 18:40:44 GMT -5
Fantastic, John. I new you could do it. Great fit. Check inside that the epoxy didn't get through the little holes. Have had that happen and it rubs it and won't close right. Also, have had new ones that didn't work right. Ken
Post by Sabre52 on Dec 8, 2011 19:19:23 GMT -5
Wow that's purdy!....Mel
catskillrocks
Member since July 2008
Post by catskillrocks on Dec 8, 2011 21:13:13 GMT -5
First or 50th, that is an impressive knife.
Don
sampson
Member since April 2011
Post by sampson on Dec 9, 2011 0:54:46 GMT -5
Pretty good for a first one. I usually say practice makes perfect but in this case it looks like you nailed it on your first try.
Post by BuiltonRock on Dec 9, 2011 7:06:56 GMT -5
Wow! Thanks for all the nice comments. I am anxious to make another one. I think the closing issue is because the spine of the knife, (where there are moving parts) was also polished and the edges are rubbing. It is getting better with use and should work out. Thanks again everyone!! John
Post by johnjsgems on Dec 9, 2011 10:39:17 GMT -5
You sure set the bar high for the next one. Great job!
adrian65
Member since February 2007
Post by adrian65 on Dec 9, 2011 11:20:54 GMT -5
Not too bad, you say? All I can see there is perfection! Great job on this knife.
Adrian
Post by Toad on Dec 9, 2011 12:01:00 GMT -5
Looks great. Keep them coming.
blr2449
Can I retire now?
Member since January 2011
Post by blr2449 on Dec 9, 2011 19:06:43 GMT -5
Wow! If this is your first one, I can hardly wait to see what you have after you get more done!!
NDK
Post by NDK on Dec 9, 2011 19:41:48 GMT -5
Beautiful piece John! Hope your boy's feeling better.
Nate
mjflinty
Member since September 2011
Post by mjflinty on Dec 10, 2011 10:06:24 GMT -5
Very nice! The colors really work well with the silver metal!
Michael
hulagrub
Member since October 2009
Post by hulagrub on Dec 10, 2011 20:48:23 GMT -5
John, great first knife!
Post by BuiltonRock on Dec 11, 2011 6:37:38 GMT -5
Thanks again everyone! I am grateful for the encouragement and have started my second one.
Post by texaswoodie on Dec 11, 2011 9:13:11 GMT -5
Great job on that knife John!
Curt
carloscinco
Post by carloscinco on Dec 11, 2011 9:22:10 GMT -5
If it is rubbing on the closing of the blade you may have some interference where the ricasso rubs against the liner. The ricasso is that part between the pivot pin and where the edge starts and is where the name of the maker is stamped. You can wrap a piece of 600 grit paper on a popsicle stick and take a little metal off the liner where the ricasso passes by the liner and see improvement. Check it often and don't take off so much that it becomes obvious or blend it in to the liner. You may just have rock dust on the moving parts. You can submerge the knife in soapy water and work it to see if it washes out.
damammy
Post by damammy on Dec 11, 2011 12:51:28 GMT -5
John, that is a great looking knife. It is great to see you back on the board, you were missed. Donna
grayfingers
Member since November 2007
Post by grayfingers on Dec 12, 2011 18:59:41 GMT -5
Amazing, you have a knack for it!
Bill
