fmelvis
Member since November 2010
Post by fmelvis on Dec 10, 2011 7:55:54 GMT -5
Using 3 lbs barrels. Should I use the recommended 6 tlbs of polish or stick with 3 like the grit?
Thanks
Post by johnjsgems on Dec 10, 2011 8:43:18 GMT -5
All polish is not equal. Top quality polish compounds like cerium, tin oxide, and micro aluminum (.3-.5 micron) 2 teaspoons will work in a 3 lb. drum. The less expensive polishes like CPP take more. Low price is not always the cheapest way to go. Some suppliers advise too much also. Not sure if it is to sell more or just not knowledgeable.
Post by stefan on Dec 12, 2011 10:16:16 GMT -5
I use 2. I new and 1 old (stuff I save from previous polish runs). A little seems to go a LOOOOOONNNNNGGGGG WAY!
charles kuchar
Post by charles kuchar on Dec 14, 2011 20:47:58 GMT -5
i splurge and use 1 tbsp of ao1000, tripoli and polish in my 3#. last batch i got out this week was beautiful. i am now doing tumbling in 50/90, then 120/200 and ao500 in the lot-o vibe and then tumbling for the polish. i might try doing ao1000 and tripoli in the vibe and then going to the tumbler for the final polish. charlie
Post by johnjsgems on Dec 14, 2011 21:07:31 GMT -5
Wish I sell Lot-O drums. 60/90 will shorten vibe tumbler drum lifespans considerably.
Post by Jack ( Yorkshire) on Dec 15, 2011 3:41:07 GMT -5
Hi I use only 1/2 a tea spoon of polish in my Lot"O"
In the rotary I used a lot more but used to use it again and again, put all the washing and old polish in a tall jar let it settle drain off the water and it was ready for the next batch + 1/4 Tea spoon of new polish every now and again when needed
Oh I used CO
Jack Yorkshire uk
