joejansal
Member since August 2009
Post by joejansal on Dec 22, 2011 17:48:05 GMT -5
hi guys, need info on the expanding wheels, i think they are called nova wheels. i have a 2 wheel rayteck grinder cabber so i am looking to change the wheels to ones that i can use different grits on any info would be appreciated thank you joe jan
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Dec 22, 2011 17:55:13 GMT -5
Expando drums and nova wheels are very different products. the first is a rubber wheel that is designed to use interchangeable belts of various grits. The second is a wheel that has a specific grit diamond coating over a flexible backing. 8" expando drums run about 75 bucks, 8" novas are about $160.
Post by stefan on Dec 23, 2011 10:15:24 GMT -5
what you need to know? Like Don said expandos will take different grit belts. You can use Silicon Oxide (cheap and fast wearing) Diamond (expensive and slow wearing) and Aluiminum Oxide (mid priced and limited selection of grit sizes- also very mixed results).
