jdupras
Member since January 2012
Post by jdupras on Jan 1, 2012 14:02:17 GMT -5
Help! Just finished my first tumble. I finished the polish and they were quite shiny. I then put them back in with Ivory soap shavings for four days. Now many of them have lost their polish and seem almost dried out. Is it because I used soap shavings and not laundry soap? And, can this be fixed by putting them back into the tumbler with polish?
Post by susand24224 on Jan 1, 2012 15:53:12 GMT -5
Hmmmm. I still have not mastered the fine art of burnishing. I used to use Borax, until it destroyed the finish on some fluorite, then I switched to Ivory Snow shavings. Most of the time they work for me. Recently, I had a batch of Mohs 5- 5 1/2 where it did not work--it was almost like a gummy surface fused onto the rocks. I went back to 1000 to get rid of it.
I am not certain of the entire cause of the occasional problem, but the following seems to affect my outcome: temperature (Ivory Soap seems to "blob" if the temperature is below 48 degrees or so). Amount: it does not take much Ivory Soap to be too much. Borax there was more room for error. Perhaps you used too much? Perhaps hardness: the only problems I have had with either Ivory or Borax were with softer rocks, but I have not had enough serious problems to be sure of this.
I also live in a house with a salt-based water softener. I think this significantly interfered with removal of Borax, not so much so with the Ivory. This makes sense--Ivory is designed to come off the skin with considerably less rinsing than that involved in laundry. As an aside, Dreft did not work at all for me--couldn't get the residue off without major effort.
The only conclusions I can draw is that usually both of them work fine, but there are variables that affect them that I haven't quite nailed down yet. I would however, use minimal amounts of any of them. If your rocks are Mohs 7, I would bet that there were a few too many Ivory Soap shavings in the mix.
Susan
Post by Sabre52 on Jan 1, 2012 16:16:59 GMT -5
Dreft baby soap works great and there's no plant toxicity issue as with borax....Mel
snuffy
Member since May 2009
Post by snuffy on Jan 1, 2012 16:20:42 GMT -5
I seldom burnish,but I never run the burnish over 24 hours when I do.4 days seems too long to me.
snuffy
Post by quartz on Jan 1, 2012 21:27:52 GMT -5
One thing that seems to affect the soap burnish process is water quality. Youngest lives in Vancouver, Wash., couldn't get a good shine for anything. He ran a batch with distilled water and it worked great. He said his freshly found rocks didn't even wash up well in the tap water.
catskillrocks
Member since July 2008
Post by catskillrocks on Jan 2, 2012 20:44:32 GMT -5
well, jdupras, as you can see, each person finds what works for them. I would say first off, that 4 days is FAR too long a time; I would think that 4 hours is a more realistic time frame. Oh, and for me, I use Ivory Snow for a burnish, when I do. This isn't Ivory Bar Soap shavings; it is actually a powder.
And as already mentioned, Borax will kill any vegetation if you pour it out where things grow.
Don
