joejansal
Member since August 2009
Post by joejansal on Jan 1, 2012 19:52:47 GMT -5
hi guys and gals, just bought a used gem lab cabber gl-ii, it has 2 diamond 6'' wheels one is 600 grit the other not marked but seems courser wheel no is 100224923848 the wheels are 1 and a half inches wide. would it be a good investment to buy an expando wheel so i can use many diff grits. if the answer is yes is there anyone that has one for sale. thank you so much
joejansal@comcast.net
Post by quartz on Jan 1, 2012 21:19:34 GMT -5
What is your shaft diameter?
joejansal
Post by joejansal on Jan 2, 2012 9:55:35 GMT -5
shaft diamater is 5/8'' looks like wheel was 1'' and bushings to 5/8 thank you
Post by Hard Rock Cafe on Jan 2, 2012 13:57:11 GMT -5
Yes, they're a good idea. You can usually find them on ebay, Kingsley North, MLS, or other shops.
Post by jakesrocks on Jan 2, 2012 14:40:43 GMT -5
Don't buy used expandos off of ebay. You may be buying someones junk. Best to buy new wheels, or from a place where you can hold them and inspect them before putting your money down. Check used wheels for signs of rot or separation of the rubber from the metal hub.
That being said, you can trust buying from our older members. We all try to treat each other fairly. Don
meta99
Ohio Flint Ridge flint
Member since October 2010
Post by meta99 on Jan 2, 2012 16:26:44 GMT -5
Consider johnjsgems....he will find you the best deal.
Sue
