Post by MyNewHobby on Mar 18, 2012 16:38:54 GMT -5
Post by MyNewHobby on Mar 18, 2012 16:41:07 GMT -5
Post by NatureNut on Mar 18, 2012 18:06:33 GMT -5
Where's the "Like" button? You go Jules! Jo
Post by talkingstones on Mar 18, 2012 18:14:25 GMT -5
You are going to have so much fun with this! Enjoy!
Cathy
Post by MyNewHobby on Mar 18, 2012 19:09:03 GMT -5
Thanks Jo! and Cathy .... I know .... ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) ! As Always!
Post by MyNewHobby on Mar 20, 2012 14:03:02 GMT -5
I think I need a refresher on vibe tumbling ... oye
First I get the awesome rolling and now it has slowed down a bit. I will recharge later today and might remove some of the glass pieces.
I am wondering if I have too much in the bowl. I do not have a great deal of slurry, so I do not think it is too wet. But you never know.
I will check it and maybe I will do what I did when I first started using a vibe couple of years ago. I will try to take a vid and let you experts tell me.
Have a great day!
Post by MyNewHobby on Mar 20, 2012 15:02:12 GMT -5
Here is the vid for the vibe. Before the day is up, I will rinse and re charge the bowl again and maybe remove some of the glass. I am wondering if I truly over packed the bowl. Let me know what you think. ![](http://i182.photobucket.com/albums/x290/SWRJC/Rocks/th_MOV06578.jpg)
Post by MyNewHobby on Mar 20, 2012 15:04:38 GMT -5
This batch speeds up just a smidge, then slows down a LOT.
Post by talkingstones on Mar 21, 2012 5:42:05 GMT -5
I found with mine...which is a Lot-O not the UV, that weight had a bigger effect on speed than volume. I ended up having to take a bit of the fill out as well. Also, you're looking kind of dry and might want to add a little water by giving it a few squirts from a spray bottle. Soap also tended to slow me down in earlier stages. I work with soap flakes (Zote). One or two flakes is good for me. Hope this helps!
Cathy
Post by connrock on Mar 21, 2012 8:56:01 GMT -5
I agree that it looks way too dry.
Plastic pellets don't work well in vibes and in this case I believe they are cushioning way too much which is probably why you're not getting much of a slurry. You DO want very small pieces in the load when doing a load with this many slabs and cabs but you'd do better with something other then plastic pellets.
Randy is the expert with the UV's so maybe a PM wouldn't hurt? Show him the video as it's a VERY good example for him to help you with.
connrock
Post by MyNewHobby on Mar 21, 2012 13:43:15 GMT -5
Hey Con and Stones Again!!
Thanks for the input again. I love input.
Am just finishing off rinsing out the entire batch and going to add nothing but small(er) rough for cushion. Funny thing is that some of the rough I will add will probably come out awesome as well.
I have gotten to the point where I really dislike working with plastic. It is a pain!!!!
I think the vids are a great help so others can truly see what I am going through.
Even after bit over 3 years, the vibe still has me a bit baffled. I just need to be patient and try out everything and anything all suggests.
Thanks Guys and As Always!
Post by connrock on Mar 22, 2012 9:33:45 GMT -5
I'm sure you'll do well with the vibe.It just takes time to learn it and to develop your own way of using it.
Good Luck,,,
conrock
