TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Apr 13, 2012 1:26:02 GMT -5
Well, I finally had enough time to wrap my pin/pendant. Here it is as a pendant, just a normal wrap. But, here is the back, showing the handmade pin attachment. And here is a photo of the pin, Hope you all like it. Tammy
cccbock
Member since December 2011
Post by cccbock on Apr 13, 2012 5:49:54 GMT -5
Thats cool.....so is the pointy part of the pin part of the wire that wraps the main part of the stone ??
TByrd
Post by TByrd on Apr 13, 2012 6:12:07 GMT -5
no it is an extra piece of wire that is added in.
Post by helens on Apr 13, 2012 20:39:41 GMT -5
What an interesting way to do that! And the pin part hooks under the other pins to prevent it from falling off the garment?
TByrd
Post by TByrd on Apr 13, 2012 22:13:22 GMT -5
You make a safty pin and sandwich it between two other wires that you pull from each side then wrap all three together. The thing is that you should make the pin out of spring hard wire.
Tammy
