billg22
Post by billg22 on May 28, 2012 17:55:45 GMT -5
I can't remember where I heard that you can use sand as grit. Might be losing my mind. If sand is possible, what would be the best kind of sand? Would you use it as the 60/90 stage?
Post by NatureNut on May 28, 2012 18:04:54 GMT -5
I've tried it. It does work, but takes a long, long time. Yes, you can use is to round things up. Where 60/90 would take a month, sand might take several to do the job. Sand is silica and is about a Mohs 7. If I'm thinking logically, anything harder than a 7 would be little affected. Somebody on here did an experiment and took pics along the way. I'll have to search for it. I'll post it if I can find it. Jo
snuffy
Member since May 2009
Post by snuffy on May 28, 2012 18:12:13 GMT -5
I wouldnt recommend it at all.Wear and tear on equipment and electricity usage justifies grit use.Sand would be just spinning your wheels,er tumblers.
snuffy
billg22
Post by billg22 on May 29, 2012 9:57:03 GMT -5
Thanks for the info. Looks like I'll stick with store bought grit.
Post by johnjsgems on May 29, 2012 10:26:07 GMT -5
I think the rocks knocking together would do more than the sand.
