Post by gr on Jun 7, 2012 23:59:34 GMT -5
I picked this up @ Q-site in 2010 and didn't write down what they said it was. thanks in advance!
Post by catmandewe on Jun 8, 2012 0:06:33 GMT -5
I would guess Serpentine from around Globe, AZ.
Tony
Post by gr on Jun 8, 2012 1:14:19 GMT -5
Isn't serpentine around 4 - 4.5 on the mohs? I haven't tested it but it seems harder than serp.
Post by Drummond Island Rocks on Jun 8, 2012 6:22:27 GMT -5
Post by jakesrocks on Jun 8, 2012 7:56:09 GMT -5
Yup, Ricolite. Got a small piece right in front of me.
Post by gr on Jun 8, 2012 10:04:11 GMT -5
Tony, you get the bingo for serpentine.
Chuck, thanks for posring that link page
Don, have you worked some of this and, how does it shine up?
Post by jakesrocks on Jun 8, 2012 10:27:42 GMT -5
I worked several cabs a few years ago. Only have a small piece left. It takes a pretty decent shine if you use a light touch on the sanding. Like most serpentine it's fibrous, so a light touch is mandatory. I just used cerium on leather, but diamond would probably bring up the best shine.
Post by Deleted on Jun 8, 2012 10:47:46 GMT -5
For a mirror polish, work it to a 1200 or 3000. Then use some zam on a buffing wheel.
Tim
Post by Pat on Jun 8, 2012 16:43:02 GMT -5
Serpentine is our (California) state rock, but it doesn't look like that! Used to be used as gravel for roads, until it was discovered that asbestos was bad for you. Last time I was in northern California, there were still green roads.
Post by gr on Jun 8, 2012 18:50:12 GMT -5
Sooo Pat, you're saying there is asbestos in serpentine?
Post by jakesrocks on Jun 8, 2012 19:03:57 GMT -5
If you work it dry, better where a mask. Work it with plenty water, and bury the mud when you clean up your machine.
Post by 3rdrockfromthefun on Jun 8, 2012 20:00:31 GMT -5
Now I know what my small piece of the same material is (looks identical to the "T"). Asbestos...? Ah man...
Post by mohs on Jun 8, 2012 22:46:34 GMT -5
that an interesting piece of rock gr do you recall where it from ? defintley as serpentenish qualities but could be marblish too
Post by jakesrocks on Jun 8, 2012 23:07:30 GMT -5
