charles kuchar
Member since November 2010
Post by charles kuchar on Jul 17, 2012 12:44:13 GMT -5
one of my lot-o's stopped last night and had one of the bearings out. i think the bearing could be changed. just checking for experience in this task. charlie
Post by johnjsgems on Jul 18, 2012 8:29:57 GMT -5
Charlie, the lack of replies may be the answer. I don't know what kind of motor it is but if you can take it apart and remove the old bearings you can replace them. Finding replacements may be hard but exact measurements and the internet should make it possible. When you take it apart pay attention to any very thin shims next to the bearings. They are thrust washers and keep the shaft centered. Bearings are either ball or sleeve. You may find replacements through a small tool repair center. The good old motor repair shops likely wouldn't carry anything small enough but may know where you could find them. Good luck.
Post by connrock on Jul 18, 2012 9:37:54 GMT -5
I've never changed Lot-O bearings but tried to change bearings on other small electric motors before. I've fit and replaced thousands of bearings in my life but I'll be darned if I could find small replacement bearings for small motors on line or anywhere else. They may be out there but finding them is another story. Good luck. connrock
charles kuchar
Post by charles kuchar on Jul 18, 2012 19:09:43 GMT -5
lot-o says they are not replaceable. they said i have to buy a new motor. since i got more time than money will fiddle with the damaged bearing and see what happens... charlie
charles kuchar
Post by charles kuchar on Jul 18, 2012 19:35:14 GMT -5
ok, took the plate with the bearing in it off the motor. right away i can see the armature shaft is too small for the bearing connection and it is not a bearing that does not need lubrication. there is a small plastic tube that goes into the bearing for lubrication. i think i can test it by shimming the shaft to be tighter in the bearing which does not turn anyway. there was some time of sawdust or something that held lubrication for the bearing. i will have to find a substitute for that, if not anything else, sawdust... charlie
Post by johnjsgems on Jul 19, 2012 8:21:06 GMT -5
If the armature shaft end is completely round the bearing likely had a center that wore away. You may be able to find a bronze bushing that fits. Look in the hardware drawers at the local hardware. Drill a hole in the bushing to line up with the oil port tube.
Post by christopherl1234 on Jul 19, 2012 17:46:20 GMT -5
charles kuchar
Post by charles kuchar on Jul 20, 2012 20:28:08 GMT -5
in looking for a shim, kellys machine shop said try a piece of an aluminum beer can. will try that tomorrow. what the heck, it might work. charlie
