joejansal
Member since August 2009
Post by joejansal on Aug 8, 2012 18:18:17 GMT -5
hi all,
need info from you experts, star diamond multi unit grinder, model gsp-8
on e-bay. who mfg star diamond, what do you guys and gals think about star diamond. any info will really be appreciated.
Post by jakesrocks on Aug 8, 2012 19:11:57 GMT -5
Star Diamond has been out of business for a number of years, but they made good, long lasting equipment.
shermlock
Member since August 2011
Post by shermlock on Aug 8, 2012 19:30:08 GMT -5
Good equipment. I have the same unit. I also have a few of their arbors and a 14" saw.
Scott
joejansal
Post by joejansal on Aug 8, 2012 19:32:33 GMT -5
thank you for that info, next question i guess, does anyone carry parts for star diamond or are other companys parts interchangeable with star diamond. if unit on e-bay sells cheap enough and parts are available it might be a good buy. thanks again joejan
YooperGal
Member since July 2012
Post by YooperGal on Aug 8, 2012 19:38:06 GMT -5
I'd like to tag along on that question joejansal... I have a star diamond vibration tumbler that I picked up and need parts for!
shermlock
Post by shermlock on Aug 8, 2012 19:41:34 GMT -5
Depends on what you are looking for. I could not find the water valves and I looked forever. Finally ended up using multiple gang valves to get the water to each wheel. Everything else seems pretty universal. Arbors, shaft, etc. The only thing you will run into is that certain Star models used a thread pattern on the end of the shaft (for a face plate) that is impossible to find. I bought a face plate that was tapped for a 3/4 screw and drilled it out. I found the correct tap at a tractor repair shop and borrowed it. Took forever to find a place that had the right tap. Scott
joejansal
Post by joejansal on Aug 8, 2012 20:17:54 GMT -5
thanks again scott,
i make wampum, which is made out of seashells, i use rotary tumblers to grind and polish them. i have been learning how to make a cab with my gem lab 2 two wheel grinder, 1 expando wheel which i have 400, 600, 1200, grinding belts and 3,000, and 14,000 diamond polishing belts this unit would save me a lot of work. joejan
Post by johnjsgems on Aug 8, 2012 20:36:35 GMT -5
Star Diamond went under in 1998 and was picked up by MK. It ran as Barranca Diamond for 8 years and then merged into MK as the lapidary division. They still make some Star Diamond equipment and carry some parts. The brass aquarium valves were replaced with expensive stainless steel valves. The vibrating flat laps dropped out before MK/BD took over. The tumbler line was sold to Lortone before they went under as well. The Star diamond equipment was very heavy duty typical of the HP/Frantom era built to last stuff.
Post by jakesrocks on Aug 8, 2012 21:22:33 GMT -5
Might check Covington for the valves. They still carry them, and have screw on spray caps for them as well.
Post by quartz on Aug 8, 2012 21:56:39 GMT -5
We have one of those Star Diamond grinding machines too, like it a lot; rugged and durable, easy to get at the wheels with the rocks.
jspencer
Member since March 2011
Post by jspencer on Aug 8, 2012 23:33:07 GMT -5
I also have a Star Diamond cabber. I like it just fine and have had no problems. The thread size for the end polishing plate is a 5/8" fine thread and backing plates are available for them from Kingsley-North.
