riverrock
Member since April 2010
Post by riverrock on Aug 19, 2012 19:41:39 GMT -5
I have seven 15 lbs thumbers tumblers and i go though a lot of pullys and bearings. And i am wondering if there is something better out there i can use?
Post by quartz on Aug 19, 2012 21:41:21 GMT -5
If you have access to a metal lathe, or know someone who does, there's a bunch of industrial plastics [Nylatron GS, and Titanium {a trade name}] that will greatly outlast the white nylon bearings. The mtl. would have to be cut to spec, but may be worth it to you. If you don't can't make them yourself, or know anyone, talk to a local machine shop.
Post by johnjsgems on Aug 20, 2012 13:18:02 GMT -5
If you are running that many 15 lbs. barrels sounds like you need a commercial duty or home built heavy duty unit.
Post by Drummond Island Rocks on Aug 20, 2012 13:48:29 GMT -5
I was going to recommend the same as John, A homemade with 3/4" steel shafts, greasable pillow block bearings and heavy duty automotive pulleys and belts. I have had mine going for a full year now and the only maintenace has been to get the grease gun out once a month. I am sure you dont want to eat the cost of all those units though.
chuck
