electricface
First fish of the day
Member since August 2012
Post by electricface on Aug 27, 2012 12:43:08 GMT -5
Was wandering. Many ppl use different types of glue. I am wanting to make jewelry using the post you insert into a drilled hole. What type glue is the best for this purpose?
Post by johnjsgems on Aug 27, 2012 16:44:17 GMT -5
My wife is partial to "G S Hypo Cement". Mostly she likes the little needle applicator in the cap. E-6000 is pretty popular too.
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Aug 27, 2012 16:49:59 GMT -5
E-6000 is what I use.
herchenx
Member since January 2012
Post by herchenx on Aug 27, 2012 17:26:45 GMT -5
yup e6000 here too
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Aug 27, 2012 17:42:22 GMT -5
Epoxy 330
Post by 150FromFundy on Aug 27, 2012 18:26:24 GMT -5
I use good old 5-Minute Epoxy. Mix well and use a toothpick to poke glue into the drilled hole. If you need more time, use good old 30-Minute Epoxy.
Hint - Make sure the drilled hole is completely dry before gluing. I had a few embarasing failures due to this. I dry my pendants in the oven (Low - 225 degrees) for 20 mintes before gluing.
Darryl.
Post by Bikerrandy on Aug 27, 2012 19:53:27 GMT -5
I've been using 330 epoxy for a long time, never any failures with it.
Post by johnjsgems on Aug 27, 2012 22:06:22 GMT -5
330 is probably the strongest jewelry glue available. A lot of people don't want to mix it though. Especially for a drop here or there.
jspencer
Member since March 2011
Post by jspencer on Aug 28, 2012 0:19:02 GMT -5
Just as important as the glue is cleaning it well first. I use acetone to clean and epoxy 330 for glue. It dries water clear and works great.
