Post by Toad on Nov 11, 2006 14:28:02 GMT -5
Here is my plan for finishing rocks once I get my vibe: - 60/90 in the rotary - 220 in the vibe - 600 in the vibe - 1000 in the vibe - Polish in the vibe
Now I know not all of you use this many steps - but let's forget about how unnecessary it might be and just assume its the right way to do it.
1000 grit silicon carbide is very expensive - about $10.50 a pound. I've heard that many people here like tripoli. Can I exchange one for the other? Tripoli is only $1.60 per pound.
That was question 1. My next question is what is the best general polish. One that works reasonably well on any stone?
Thanks.
Toad
agatemaggot
Member since August 2006
Post by agatemaggot on Nov 11, 2006 15:36:53 GMT -5
Toad, After 600 grit we use Micron alumna pre polish for 1 day then 1 day with TXP polish. Don't have a clue what either of these critters are made up of, but our agate leaves the polish cycle looking like wet glass. We buy all our supplies from :
Minnesota Lapidary Supply . com Owner : Val Carver Store Mgr. : Dee Phone # 763-631-0405
Mr. Carver knows vibes inside and out.
Post by deb193 on Nov 11, 2006 15:55:45 GMT -5
I like the RockSHed AO polish. They also have a 1000g AO, that is like the Tripoly. YOu could get both polishes, some ceramic pellets, and maybe even some rough all in a flat rate box. What a deal.
Post by Toad on Nov 11, 2006 17:45:46 GMT -5
What's TXP?
Post by Sabre52 on Nov 11, 2006 19:55:58 GMT -5
I have had real good luck with tripoli as my prepolish as long as I don't add to much to the barrel as this can bog down your load pretty easily....mel
Post by Bikerrandy on Nov 11, 2006 21:09:07 GMT -5
I never use any pre-polish, I go from 500 grit straight to the polish. Hmmmm, give me a couple minutes and I'll show you how one the thundereggs that you sent me turned out.
Post by Bikerrandy on Nov 11, 2006 21:33:32 GMT -5
Here ya go, I cut these from a rock that you sent me, 4 day in 120/220, 4 days in 500, and 4 days in AO from the Rockshed. I can't take a pic of the shine worth a damn......
Post by Toad on Nov 11, 2006 21:39:39 GMT -5
Look nice. Did you have much trouble with undercutting between different areas? Is AO the only polish you use?
Post by Bikerrandy on Nov 11, 2006 21:51:58 GMT -5
No trouble with undercutting at all, and yes, AO is the only polish that I ever use. It makes all my stuff shine like glass!
agatemaggot
Post by agatemaggot on Nov 11, 2006 22:15:31 GMT -5
The TXP is a final polish for hard agate type stone. We use a product called Micron alumina for prepolish. 24 hours in each. Don't have a clue what it is but it shines the livin S__t out of agate.
donsimpson
Duncan and Mari's Dad
Member since September 2006
Post by donsimpson on Nov 11, 2006 23:34:28 GMT -5
Alumina = aluminum oxide. Corundum is the naturally occurring mineral form of aluminum oxide (ruby, sapphire, emery). 9 on Mohs scale.
lsmike
Maxwell's demon lowers tumbling entropy
Member since January 2007
Post by lsmike on Jan 6, 2007 11:22:15 GMT -5
TXP is a propritory polish that is AO based and only MN.Lapidary can sell it.It is economical ;Val says to use one-half teaspoon per 10 lbs. of rock in a vibe !! It works; apparently less is more.
