megaton
Heart of Stones
Member since September 2012
Post by megaton on Sept 19, 2012 0:31:55 GMT -5
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Sept 19, 2012 11:35:22 GMT -5
see if it is magnetic. it looks like iron ore (magnetite) to me.
Post by Hard Rock Cafe on Sept 19, 2012 15:15:14 GMT -5
In addition to a scratch test, a streak test helps identify minerals. If it leaves a red streak on rough porcelain (like the back of a porcelain tile), it is likely hematite.
megaton
Heart of Stones
Post by megaton on Sept 19, 2012 15:32:09 GMT -5
Sweet, thanks. I will check that out and post back!
megaton
Heart of Stones
Post by megaton on Sept 19, 2012 15:44:08 GMT -5
The streak test proved to have an exact color as the rock. It was almost like a graphite in color and how it powdered across the plate.
I'm thinking that possible it is graphite.
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Sept 19, 2012 16:16:33 GMT -5
Marcasite is an iron sulfide, it streaks dark grey to black and is found in the Racine area. It has a hardness of 6.5, but it crumbles easily. Turns to powder eventually. Graphite should not feel heavy.
megaton
Heart of Stones
Post by megaton on Sept 19, 2012 17:11:14 GMT -5
The weight was my only reservation on the graphite thought. I'll look into your suggestion. Thank you!
Post by jakesrocks on Sept 19, 2012 22:06:55 GMT -5
How about Galena ? Galena is an ore of lead which was heavily mined in Wisconsin. Hardness - 2-1/2 S.G.- 7.4 to 7.6 (heavy) Streak - lead gray. Besides the normal cubic habit, galena is also found in masses. Try to flake a piece off. If the edges of the flake are at 90 Deg., it's a fair bet that's what you found.
megaton
Heart of Stones
Post by megaton on Sept 20, 2012 11:39:22 GMT -5
All signs point to Galena. Thank you too all who helped and to who solved.
Post by Hard Rock Cafe on Sept 20, 2012 12:18:35 GMT -5
Well done Don!
Post by jakesrocks on Sept 20, 2012 15:51:16 GMT -5
Allen, now you can knock a small chip off of it and build your very own crystal radio.
megaton
Heart of Stones
Post by megaton on Sept 20, 2012 16:04:36 GMT -5
Sweet! Plus I have all the necessary parts laying about. Weak reception, here I come!
