megaton
Heart of Stones
Member since September 2012
Post by megaton on Sept 20, 2012 13:46:05 GMT -5
Any one care to venture a guess just off of looks alone? I can do some hardness ans streak testing if needed, but I'm thinking this one will be easy for this group. Many thanks!
Post by jakesrocks on Sept 20, 2012 14:07:04 GMT -5
Looks like an agate nodule with all of the matrix knocked off by river tumbling. A slice or 2 across the eye should produce some nice banding from what I can see.
megaton
Heart of Stones
Post by megaton on Sept 20, 2012 14:21:30 GMT -5
Thanks much. I never really know which direction to cut. Most things are experimental for me right now. I'll post pictures of the cut tonight.
And to further your expert eye, this rock was picked up along the dry bank of the Pike River. So, river tumbled for sure.
Thanks again!
rockingthenorth
Member since January 2012
Post by rockingthenorth on Sept 20, 2012 20:51:40 GMT -5
It's neat what ever it is
Post by johnjsgems on Sept 21, 2012 12:53:51 GMT -5
I was going to guess an amygdule (probably not spelled correctly). You can find them in the Wiley Well area in CA. Some attached to the lava outcrop and some popping loose and on the ground. The ones from there are white with banding and sometimes fortification patterns. Basically a nodule that forms in pockets so no outer matrix like geodes or nodules
Post by Fossilman on Sept 22, 2012 1:08:04 GMT -5
Quartz based agate...............
Post by tandl on Nov 7, 2012 18:28:04 GMT -5
Agate geode . appears to be after coral.
