Post by jamesp on Oct 25, 2012 22:30:35 GMT -5
The Washington Mills(large manufacturer of AO and S.Carbide) salesman said that heat breaks down silicon carbide at a much higher rate.Ironically mine are in my greenhouse and he said that it too hot in there.He said the metal tumbling industry sees a lot of heat problems Attachments:
Post by geoff on Oct 25, 2012 22:38:08 GMT -5
I keep mine in Alaska. Seems to help.
Post by jamesp on Oct 25, 2012 22:57:40 GMT -5
Perhaps too cold Geoff.
Post by rockrookie on Oct 26, 2012 6:43:06 GMT -5
i love the greenhouse , James !!
Post by jamesp on Oct 26, 2012 9:46:58 GMT -5
I always tell my wife i am there working our plants(our bussiness).The plants in that greenhouse are much better kept than the other three houses.And thanks Paul.Make sure that bear is going to behave.
keystonecops
Member since October 2010
Post by keystonecops on Oct 26, 2012 10:10:39 GMT -5
Kewl James, Ya canhave a salad while yer tumbln. Later Clyde
Post by Hard Rock Cafe on Oct 26, 2012 16:35:39 GMT -5
LOL Geoff. I think the only real issue would be the motors heating up. I have a hard time believing that the SiC in a tumbler is going to get hot enough to affect it.
Nice greenhouse!
Post by jamesp on Oct 26, 2012 19:08:57 GMT -5
The finishing tumblers run slow and never get hot.But this summer the 45 pound barrels that run at 80 RPM for coarse grind got very hot.And they were building a lot of gas pressure too.
Post by Toad on Oct 26, 2012 20:17:48 GMT -5
I also don't think the temperatures reached in a tumbler would affect the SiC - especially considering the temps it is made at. My worry is the motor heating up the barrel so that gases build up. I train a fan on it to keep the right hand barrel cool.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Oct 27, 2012 0:09:29 GMT -5
The finishing tumblers run slow and never get hot.But this summer the 45 pound barrels that run at 80 RPM for coarse grind got very hot.And they were building a lot of gas pressure too. When you fill your barrels use hot water and you shouldn't has as much of a problem with gas build up.. that's what I do and I have my QT66 running in my carport 24/7, I also went out and bought a little 4inch fan that blows on the motor because it always runs hot during the day.
Post by jamesp on Oct 27, 2012 2:37:06 GMT -5
I guess the hot water cools and sets up a vacumn-novel idea.I know how to blow up a tumbler barrel-tumble concrete.I would pour agate chips,glass ceramics whatever in high strength concrete,then saw and break up for tumbler.Called it vomit jewelry and it was one of best sellers.Check it out Mario Attachments:
Post by jamesp on Oct 27, 2012 2:38:27 GMT -5
Here's another Attachments:
Post by jamesp on Oct 27, 2012 2:42:12 GMT -5
Yet another.Ended up using pvc barrel with a pvc threaded cap.Had to grease threads well to get it apart.Probably had 30- 40 psi in it.Totally dangerous to remove cap.Have a chipped tooth:> Attachments:
electricface
First fish of the day
Member since August 2012
Post by electricface on Oct 28, 2012 19:26:17 GMT -5
Verry cool idea James.
Post by jamesp on Oct 29, 2012 6:17:03 GMT -5
Thankyou Tony
