sheltie
Member since January 2012
Post by sheltie on Nov 17, 2012 12:24:09 GMT -5
One of the (many) things about learning a new hobby without proper help is that you go off on a tangent. I went crazy collecting and subsequently slabbing many pieces of rough. Before I started to realize that I should've labeled what the slabs were and where they came from, I had several hundred done! Most I was able to go back and ID but the one's in the link I've not been able to. Most are either agate or jasper. WARNING! There are about 28 I really need help with but I'm afraid that the flikr account I used also will allow you to look at all my stored photos. I couldn't think of a better way to show them all together without bogging down the forum so I'm open to suggestions for other ways as well. You are absolutely welcome to do so but I suspect you will become bored looking at vacation pix. If you can, I'd appreciate your help in IDing the 28 photos at the beginning. Several of them are duplicates (agates) as I wanted them to be seen in the sun and all are pictured wet. Thanks in advance for your help. www.flickr.com/photos/organize/?start_batch=recent_uploads
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Nov 17, 2012 13:09:08 GMT -5
the link is wrong.. it is a link to stating your own uploads not to your photos.
sheltie
Post by sheltie on Nov 17, 2012 13:38:38 GMT -5
Hmmm. I just tried it and it took me right to the pix. Any suggestions as to how to group all of them together and segregate from the rest of my pix?
Minnesota Daniel
A COUPLE LAKERS
Member since August 2011
Post by Minnesota Daniel on Nov 17, 2012 17:54:27 GMT -5
Sheltie, look at the URL in the window at the top of your Flickr page. What Dad_Ohs means is that your link is only for you, inside your account when you are logged in. It won't work for anyone else, even if they are logged in to Flickr.
sheltie
Post by sheltie on Nov 18, 2012 11:53:43 GMT -5
Sheltie, look at the URL in the window at the top of your Flickr page. What Dad_Ohs means is that your link is only for you, inside your account when you are logged in. It won't work for anyone else, even if they are logged in to Flickr. Try as hard as I can but flikr is smarter than me. I can't figure out a way to group the pictures into a folder or something similar wo that other can look at them without having access to all my other pictures. Any ideas?
Minnesota Daniel
A COUPLE LAKERS
Post by Minnesota Daniel on Nov 19, 2012 0:49:31 GMT -5
If all your other pictures are public, then there is no way to keep us from seeing them. If however you make them Friend or Family, and then put the pictures you want us to see into a set, and post the link to the set, then you'd get your wish.
