timloco
Member since April 2012
Post by timloco on Jan 4, 2013 13:42:01 GMT -5
I have some epidosite that is really nice except it's pretty fractured. I'd like to try putting super glue in the cracks and see if that will keep the grit out and hold the rock together through the polishing. Has anyone tried this, does it work?
Post by johnjsgems on Jan 4, 2013 15:01:26 GMT -5
I'm guessing no. I use super glues on fractures on large specimens I grind/polish with my wet polisher. The glue doesn't always survive. The rocks would have to be really clean to have any chance.
Post by quartz on Jan 4, 2013 22:32:49 GMT -5
Super glue is, to a degree, water soluble. That's how to get glued fingers, or any thing else, back apart; soak in water. I use epoxy.
timloco
Post by timloco on Jan 5, 2013 14:27:33 GMT -5
yea I guess bad material is bad material. I should just be brutally honest about the rocks I'm spending grit on.
jspencer
Member since March 2011
Post by jspencer on Jan 5, 2013 22:15:39 GMT -5
To use any type of filler it`s important to first give it a cleaning with acetone or a mild acid solution and allowed to dry. Otherwise filler won`t bond well to stone.
timloco
Post by timloco on Jan 6, 2013 14:10:41 GMT -5
That's good advice. I'll have to play around with it. Right now I'm just seeing how far I need to grind them down in stage 1 to get around the fractures. Some of them are pretty deep. It's good and hard material too so it should shiny up nice.
Post by tntmom on Jan 6, 2013 14:36:08 GMT -5
I use Hxtal to fill in pits and fractures on slabs and have used the scrap slab pieces in my tumblers with excellent results. It's completely water proof but it's also expensive.
riverbendlapidary
Member since September 2006
Post by riverbendlapidary on Jan 11, 2013 23:49:49 GMT -5
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Jan 12, 2013 2:04:25 GMT -5
very cool... may have to get some of the thin stuff to see how it works on some highly fractured material I have. I want to save the Opticon for really $$ pieces.
riverbendlapidary
Post by riverbendlapidary on Jan 13, 2013 4:05:59 GMT -5
the red is great for hairline and healed fractures. for pits and larger stuff, get the super t.
jspencer
Post by jspencer on Jan 13, 2013 22:41:00 GMT -5
I found a thick gel type super glue at Home Depot that sets fast and holds well for filling small voids. Not for hairline or deep wounds probably. There is less drip with this stuff than the red tubes.
