zarguy
Member since December 2005
Post by zarguy on Jan 15, 2013 1:24:43 GMT -5
I've got a Highland Park WBS (Wet Belt Sander) unit for sale. It comes with 6 320 grit belts & 12 600 grit belts. The belts are 3x41.5". The Minnesota Lapidary Supply catalog has new belts for $5.60 ea. It has an adjustment knob for belt tension & another know for alignment. There's also a quick release for swapping belts without altering the 2 adjustments. It has a 10" diameter polishing pad on the end. It comes with a second 10" pad, so you can switch between 2 different polishing compounds. These pads are leather stretched over domed aluminum. The machine is in great shape. The motor is a GeneralElectric 1/3 hp. It has the original hammered green & tan paint, with just a little surface rust on some of the unpainted steel parts. The upper drum is 4 3/16" wide. The lower drum is 3" wide. If you could come up with a 4" wide lower drum, you could use this with 4" belts. The price is $525. I live in Cedar City, Utah & will not ship it, but you can pick it up from me if you're traveling this way. I'm going to be in Quartzite Jan 22 - 26 & we could arrange to make the transaction there. PM me if you're interested. I'll be listing a couple other machines too. The belt
Post by catmandewe on Jan 15, 2013 9:08:23 GMT -5
I'll take it, bring it to Q when you come.
Tony
zarguy
Post by zarguy on Jan 15, 2013 14:43:06 GMT -5
OK, Tony. See you there.
Lynn
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Jan 15, 2013 15:05:55 GMT -5
you got a nice piece there ... gratz!!
