vwfence
Post by vwfence on Feb 2, 2013 10:20:06 GMT -5
Does anyone know of a company that refurbish's diamond saw blades ? Thanks Wayne
Post by Rockoonz on Feb 2, 2013 19:39:08 GMT -5
By refurbish do you mean new diamonds or straightening bent ones? There are a few saw guys left who will straighten them, but I have never heard of new diamonds except replacing the sintered cleats on drag saw blades.
Lee
vwfence
Post by vwfence on Feb 2, 2013 22:18:29 GMT -5
i meant adding new diamond
Post by deb193redux on Feb 2, 2013 22:39:55 GMT -5
nobody does that
marinedad
Member since December 2010
Post by marinedad on Feb 3, 2013 23:56:25 GMT -5
isn't there some metal missing on worn blades? a new 16" blade is 16" one that is worn down would be 15 5/8 plus or minus, right or am i wrong?
cherdarock
Member since December 2012
Post by cherdarock on Feb 23, 2013 0:11:12 GMT -5
If you can cut an accurate disc w/center hole on center, get some copper or brass plate @ 1/16" thickness. Cut and true to size, then with a chisel notch the disk edge all the way round at 1/8" increments. Roll the disc edge in some 100-150 mesh SiC coated diamond grit, jamming the grit into the notches. "flat" roll the disk. This will pinch the grit, holding it in the notches. BAM!!! diamond blade.
