Post by kk on Apr 23, 2013 7:45:55 GMT -5
Hi everyone. Have a few projects going at the same time, all involve main-pieces with add ons. The add-ons seem to take just as much time as the pieces themselves. Here in this case, I tried a calcite flame, that turned out OK but too large and I think it would not have survived the mounting/wear. Started with a thick slab (over half an inch) so had lots of space to dig through. While the slab says: copper type, the section I used does not include any copper sheets. Some stages Finally done cutting And finished It comes in at 58 x 42 mm including the mounted (pin connecting hand with tourmaline) tourmaline Finally, the best picture from today Thanks for looking, have a great week, Kurt
Post by FrogAndBearCreations on Apr 23, 2013 10:49:26 GMT -5
Wow, very nice!
Post by gr on Apr 23, 2013 11:12:17 GMT -5
Although carving has not interested me much in the past, I'm certainly gaining a new apperciation for it in seeing these amazing pieces that you produce. This one is no exception, except that, it is exceptional! I almost bit my toung typing that, Lol! Very nice work Kurt!
Post by kk on Apr 23, 2013 16:59:40 GMT -5
Thanks guys, its a fun experiment. I like trying something new and with combos of stone and designs, you never run out of new challenges.
Gr; just take an existing cab, draw some design on it and give it a shot (cameo like), you will see how quickly you can turn an average cab into something special. Can't draw? Use carbon-paper, and then go it on your own.
Post by gr on Apr 23, 2013 17:46:34 GMT -5
Kurt, I have a project coming up that requires a little edge carving. Who knows where it will go once I get my feet wet. I like your idea!
Post by kk on Apr 23, 2013 21:33:38 GMT -5
Right on. Let me go back and find some pictures from two years ago where I started out exactli like that; with borders and lines on usually broken cabs.
Post by Tommy on Apr 23, 2013 23:44:29 GMT -5
Beautiful work Kurt! What continues to amaze me about what you do is how you avoid breaking the piece. The 'finished' photo showing the cords passing through the back - that would have broken on me just for THINKING about trying to create it...seriously.
Post by kk on Apr 24, 2013 5:47:40 GMT -5
Gr: The snake is dated June 2011 and the others are from April, so exactly 2 years ago. So you see, I have come some way in this time. But I do have to admit that I fell completely in love with this hobby, and I have/had virtually no social or family obligations that would have kept me from doing at least something, every other day. Tommy: I have been lucky in this regard. The back was planed to have a solid hole going all the way through, but the material is just too nice to waste. So there was no way to get a straight set on the core-drill. I used ball-burrs and with the piece being fairly thick, I was able to open another hole in the center to give me 4 access-points to make it possible. Just needed to keep the pressure forward down and never up. That's of-course easier said than done. Hence, I have kept, and keep quiet about "Aqua" the piece for which this one was practice. That specific material is prone to "accidents" and has given me multitudes of near heart-attacks over the past 3 weeks. By now, its nearly done, but until the hole for the pin to hold another object is drilled, I'm not going to show it as I worry that everything might still fall apart. So in short, I have breakages just like everyone else, but as I do not have to have a single-minded outcome to work towards to, I can usually adjust. Quite often something started turns into something completely different by the time its done. You will see the difference between "Phoenix" and "Aqua" because of all the problems with the other material despite starting with the same basic design. Aqua is a lot more, lets call it, "abstract". But if it works, that one will be mine and mine alone, because its the most beautiful stone I have had the luck of working with.
Post by jamesp on Apr 24, 2013 14:21:47 GMT -5
You are an amazing artist Kurt.We are fortunate to be in your presence.Can i have your model's phone number?:>
Post by kk on Apr 24, 2013 17:19:53 GMT -5
Post by jamesp on Apr 26, 2013 5:01:08 GMT -5
That is pure ice water dumped on sultry thoughts.Maybe we should stick to playing with rocks and be attentive to dearest wives-especially in your neighborhood!LOL Your humor is as colorful as your art!Great start to day:>
Post by Deleted on Apr 26, 2013 14:05:28 GMT -5
you guys kill me. KK I am noticing the more you do, the more detail you put in. Keep getting better. Me? No carving for me. I'd be embarrassed in your presence! Jim sent me this image after reading your post. He had to shower himself in icewater.
Post by kk on Apr 26, 2013 18:26:28 GMT -5
Arghhh. Icewater is to extreme for me. Live by the sea and I'm not going for a swim right now because its too cold (our water is "only" in the seventies Fahrenheit right now). Scott: the only embarrassment to be had here is when giving in to demeaning thought. I was very lucky two years ago to have people supporting me despite the insignificant results. It has grown a little since; yet I still have a long way to go to deserve praise or come close to the masters in the field. Gotta start somewhere, and as long as you keep at it, will always have words of encouragement for you. Best regards, Kurt
Post by jamesp on Apr 26, 2013 19:36:04 GMT -5
This was a great way to end my day.Thanks Scott and kk.Y'all ain't right:>
