sheltie
Member since January 2012
Zam
May 13, 2013 10:27:22 GMT -5
Post by sheltie on May 13, 2013 10:27:22 GMT -5
I've seen Zam mentioned several times in this forum and I've Googled it but I'm still not sure how, or if, if may apply to what I do. I'm always interested in finding some way of getting a higher shine on my slabs but thus far using a wet polisher has been the best for me. Is Zam used AFTER my final polish, during or what? How is it used? I haven't used any enhancer to date but am not adverse to doing so.
Zam
May 13, 2013 11:18:37 GMT -5
Post by mohs on May 13, 2013 11:18:37 GMT -5
There is a u-tube video where the person goes through the step of grinding a cab he buffed this stone with Zam to me it seemed counter intuitive cause the stone was some sort of agate and I usually use Zam for softer stones serpentine and such
although as a final finish on a hard stone it doesn't seem to hurt a warm stone seems to help maybe it just a polishing wax compound ? I use a cotton buff on my Foredom for this
I've look into the technical data on zam and it does have some abrasive quality it great on brass
that u-tube video is worth checking out
Zam
May 13, 2013 11:48:10 GMT -5
Post by NatureNut on May 13, 2013 11:48:10 GMT -5
I use Zam when I can't get a decent shine with my regular polishing system (mine is diamond but it could be Cerium Oxide, Tin Oxide, Aluminum Oxide, etc.) Usually with softer stones like Ed said.
Zam
May 13, 2013 11:56:44 GMT -5
Post by Jugglerguy on May 13, 2013 11:56:44 GMT -5
I don't know much about Zam, but I use it on Petoskey Stones, which are soft. I also heard that it is an abrasive used on soft metals and stones.
I was in a Petoskey Stone shop in the town of Petoskey recently. The lady there showed me her shop and explained how she does her stones. She only works with Petoskey stones, nothing else. The shop was green with Zam dust. After using a 600 grit wheel, she uses a soft buffing wheel with Zam as the last step. I do the same thing, but I use a small cotton wheel on my Dremel to polish with Zam. It makes a huge difference on Petoskeys.
Zam
May 13, 2013 12:41:23 GMT -5
Post by Deleted on May 13, 2013 12:41:23 GMT -5
Zam
May 13, 2013 15:36:34 GMT -5
Post by Pat on May 13, 2013 15:36:34 GMT -5
We use ZAM on sterling, and if a stone is already set in it, it's not a problem. Doesn't hurt soft stones either.
