Post by orrum on Jun 19, 2013 5:08:43 GMT -5
I use my little 6 inch Raytech saw with slabbing attachment and homemade gravity feed to slab small rocks. On hard stuff I have to cut a old piece of broken 100 grit sc grinding wheel every slab. So I cut a slice off the wheel and then I slice the slice into smaller slices like matchsticks. Can I put these in my barrel to use for the 60/90 grit? I have accumulated about a cup or so of this material. Should I put part 60/90 and part scrap sc wheel pieces or just use all little matchstick pieces?
Post by jamesp on Jun 19, 2013 7:24:34 GMT -5
Most grinding wheels are aluminum oxide Bill.And some low grade binder to keep them fused together.
I have a couple of 5 gallon buckets of 8" grinding wheels broke into pieces i use for removing limestone coating off coral in my big tumblers. Most of them are round balls from 1/2 to 2 inches.
Grinding wheels are not worth a crap for tumbling agates though.And they turn to mush pretty quickl:>Maybe great for labrodolite/felspar and other softies...
Post by orrum on Jun 19, 2013 16:19:03 GMT -5
James these pieces are from my worn out 100 grit sc hard wheel off my lapidary arbor , arent these silicon carbide? How big is your "big" tumbler if you.put two inch hunks of grinding wheels in? LOL Is it the big tire in your pic?
Post by orrum on Jun 20, 2013 7:16:26 GMT -5
Allright I emptyed the tumblers yesterday after running two weeks with 60/90 grit. My first tumble project and looks good to me. I reliaded the 1.5# barrell just like before with two tablespoons of 60/90. The 4# barrel I put two tablespoons of 60/90 and two tablespoons of little sticks of the 100 grit sc wheel. Last time I used 4 tablespoons of 60/90. We will see how it works out.
Post by jamesp on Jun 20, 2013 9:18:21 GMT -5
That tire failed Bill.But i do have several 35 pounders running and i do tumble rocks up to 1/2 pound and i do use those broken up grind wheel chunks for padding/cutting when those big rocks are being tumbled. Yes.the SC lapidary wheels are bad to the bone and should serve you well in the tumbler
