tkvancil
Member since September 2011
Post by tkvancil on Jul 27, 2013 12:42:29 GMT -5
I kinda messed this one up. When the volume on the quartz went down I mixed them with agates and got some cracks and chips where they didn't have any before. Should of went with ceramic filler instead.......Ah well lesson learned. There is also some small, already polished river pebbles (agate?) that I added to the polish barrel for volume pictured as well. Otherwise I felt like there would have been too much plastic. Rough is from the Rock Shed and was a good mix of sizes ready to tumble. The batch Something a little closer A few of the larger pieces The blue "flash" in this one changes color from yellow to red to blue depending on the orientation, which I thought was pretty cool
grizman
Member since July 2011
Post by grizman on Jul 27, 2013 13:51:58 GMT -5
Very cool, no doubt. You got a great shine on all of that batch.
Post by Bikerrandy on Jul 27, 2013 21:15:20 GMT -5
I haven't seen rutile on here in a long time. Great batch!
panamark
Member since September 2012
Post by panamark on Jul 27, 2013 22:38:17 GMT -5
Very nice! Thx
Post by pghram on Jul 29, 2013 9:43:26 GMT -5
That can be a difficult material to tumble but you did a great job. I really enjoy seeing your tumbles, thanks.
Rich
Post by Fossilman on Aug 6, 2013 10:52:08 GMT -5
I like em'!
riverrock
Member since April 2010
Post by riverrock on Aug 7, 2013 8:55:06 GMT -5
The shine and shaping are very cool.
rollingstone
Member since July 2009
Post by rollingstone on Aug 8, 2013 0:36:45 GMT -5
Sweet stones with a great shine! -Don
Post by jamesp on Aug 8, 2013 4:16:51 GMT -5
I run sensitive rose quartz with agate. The rose quartz rounds much faster like those rutilatated quartz do. To keep the rose quartz from frosting I keep the barrel over 3/4 but less the 7/8 full and use no ceramic or plastic. Rose quartz will sure frost if it is impacting hard.
I run a few rose quartz in every load of agate/jasper/coral to see if the load caused it too frost. As a monitor. In the faster coarse grind tumbler I often want the load to run a little more violent and will take some rocks out till the rose quartz does frost a bit. The agate rarely frosts.
Looks like your system needs no improvement. Those are beauties.
Post by Drummond Island Rocks on Aug 8, 2013 18:44:10 GMT -5
that's some cool material and you got a good shine on it too.
snuffy
Member since May 2009
Post by snuffy on Aug 12, 2013 10:12:11 GMT -5
Fine batch. Always like to see rutilated quartz.
snuffy
