snuffy
Member since May 2009
Post by snuffy on Aug 16, 2013 8:21:59 GMT -5
Looks like obsidian week on here with Julies fine batch a couple days ago.I wasn't going to mess with ob again,but had a lot of scrap from slabbing,trying to knap,and end cuts. This was a different method I tried.I ran a 12lb barrel in one coarse charge for 27 days. Then went to 2 Loto loads in 1000,4 days,and ao polish,3 days. The batch Ihad some large chunks in the load.These ended up frosted,I guess from banging against each other in the 12lb barrel.Surprisingly,all the small pieces and slabs weren't frosted. Snowflake,again some frosting on the large pieces. These slabs are from Tonys Davis Creek Tears,small for cushioning. Overall,pleased with it,even with the frosting on the large pieces,can work on them later. Thanks for your time. snuffy
Post by pghram on Aug 16, 2013 11:48:11 GMT -5
Nice, I especially like the snow flake.
Rich
Post by Sabre52 on Aug 16, 2013 17:02:14 GMT -5
Those came out looking real good. I guess this is obsidian month. Lowell gave me enough apache tears for a batch so I have them in the rotary right now. I had me enough tin oxide left for a batch so decided I'd give them a shot and see if I could make them come out as well as the last batch I tried. Usually I mess up obsidian so two good batches in a row would be something special for me *L*.....Mel
Post by jamesp on Aug 16, 2013 18:38:10 GMT -5
That is my experience Snuffy. Big rocks frost more. Got to run them slow or have barrel fuller than normal.
Makes sense. Tiny rocks can not beat each other and can be run very fast.
They are fine and wide variety
plumberinaz
Member since June 2013
Post by plumberinaz on Aug 16, 2013 19:42:20 GMT -5
Beautiful stuff! I got acouple pounds of Apache tears that are going in the tumbler after my Amethyst is done polishing! I'll post pics after they are done.
carloscinco
Member since July 2008
Post by carloscinco on Aug 17, 2013 9:08:25 GMT -5
Nice variety in that purty batch. Obsidian is one of those stones, along with labradorite that gives me fits. Seeing evidence from your batch that it ain't impossible to be successful is reassuring.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Aug 17, 2013 10:21:12 GMT -5
I gots a question... I have about 20 or so pounds of Apache Tears and lots of OB in different flavors..... Is Cerium good for polish, or, as I saw above, Tin Oxide better for polishing?? more curious than anything... I even have some AO polish floating around here somewhere.
Also curious about Snuffy's tumbling procedure.. you did 1 charge of course grit and left it to break down to finer grits for as opposed to changing grits in the normal progression??
snuffy
Post by snuffy on Aug 17, 2013 10:38:41 GMT -5
I gots a question... I have about 20 or so pounds of Apache Tears and lots of OB in different flavors..... Is Cerium good for polish, or, as I saw above, Tin Oxide better for polishing?? more curious than anything... I even have some AO polish floating around here somewhere. Also curious about Snuffy's tumbling procedure.. you did 1 charge of course grit and left it to break down to finer grits for as opposed to changing grits in the normal progression?? Mario,I just let the one 60/90 charge break down over the 27 days in the rotary. snuffy
cardiobill
Member since March 2012
Post by cardiobill on Aug 17, 2013 15:49:54 GMT -5
Snuffy, I always like your posts / photos. I'm used to seeing your pet wood. Nice job on the obsidian. I like the smaller tears. The snowflakes are sweet.
Bill
sheltie
Member since January 2012
Post by sheltie on Aug 17, 2013 18:41:19 GMT -5
Is it really obsidian month in central TX? I've been cutting a bunch of slabs of rainbow obsidian that I got from Tony. It's amazing the clarity of the "stripes" on the slabs. The guys from OR seem to poo pah Obsidian but I kinda like it. Of course, I poo pah flint and they like that. Go figure.
The Dad_Ohs
Post by The Dad_Ohs on Aug 19, 2013 11:16:00 GMT -5
Mario,I just let the one 60/90 charge break down over the 27 days in the rotary. snuffy very cool!!!! Thanx Snuffy !!
riverrock
Member since April 2010
Post by riverrock on Aug 20, 2013 7:00:56 GMT -5
Always nice to see the trees in your rocks.
