minerken
Member since August 2013
Post by minerken on Sept 4, 2013 23:14:06 GMT -5
I am not a wire wrapper and am not sure I will try, but I have ideas swimming through my head. Sooooo one of the patterns I like is the herring bone wrap but it seems that it is confined to beads, is there away to use a cab not drilled? One way I was thinking might work would be a wire soldered to a back plate glued to the back of the cab or may be using a grooved cab, so would one of these ideas work or does someone here have a better solution?
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Sept 26, 2013 17:07:38 GMT -5
You might be able to do a prong wrap on a cab, leaving a longer top and bottom straight wire and then do the herringbone wrap around it that way, I think that I will have to try this and then post a photo if anyone would like to see it.
Tammy
minerken
Post by minerken on Sept 26, 2013 21:12:24 GMT -5
hey Tbird do it. You might inspire me to take up wrapping
Post by wireholic on Sept 27, 2013 18:35:25 GMT -5
You could also do a sculpting harness to start
Post by drocknut on Sept 28, 2013 21:43:24 GMT -5
That could be interesting. I'd like to see what you come up with Tammy.
Post by wireholic on Oct 2, 2013 15:48:25 GMT -5
OK - I had to try this. If I can get the pictures to post - this was my 3rd attempt. I used 16g for the frame wire and 20g for the herringbone part. I think 18g would have stayed in place better, but I didn't have any. I had to put a curl in the lockdown wire to get the right curve to start the herringbone and my wire wasn't long enough to do more than a couple passes, but all in all - I think it came out OK
Post by wireholic on Oct 2, 2013 15:52:35 GMT -5
Well it posted as a link to my pintrest instead of a picture but here's the back if you want to see how the main harness is done
Post by pghram on Oct 3, 2013 12:50:49 GMT -5
Nice wrap. It's hard to think out side the stone for me, but you really nailed it.
Rich
gerard
Member since April 2011
Post by gerard on Oct 3, 2013 12:59:22 GMT -5
This thread mad me think of this video
Post by pghram on Oct 3, 2013 13:18:33 GMT -5
Thanks for the video gerard & the idea minerken.
Rich
Post by drocknut on Oct 3, 2013 13:27:35 GMT -5
That looks good. Great that you could form an idea into a wrap.
