geodehunter
Member since October 2013
Post by geodehunter on Oct 5, 2013 13:47:00 GMT -5
After reading numerious threads I have come to the conclusion that the UV10 will be to big for my needs. I'm going to try and find a good used Lot-O and give it a try. I only do about 4 to 5 pounds of rock at a time. My question to the membership do you think I'm on the right track going with the Lot-O. TIA
kaldorlon
Post by kaldorlon on Oct 5, 2013 15:17:10 GMT -5
Other option might be a UV3...
Post by Jugglerguy on Oct 5, 2013 16:11:22 GMT -5
I have a Lot-O and I love it. I've heard good things about the UV's though.
herchenx
Member since January 2012
Post by herchenx on Oct 5, 2013 16:28:29 GMT -5
I have the uv10 and it is great. I keep it pretty full of ceramic media so I can do as little or as much as I want at a time.
Either are great, lots of folks swear by either.
grayfingers
Member since November 2007
Post by grayfingers on Oct 5, 2013 16:54:39 GMT -5
Probably can't go too far wrong with either choice. I have the UV 10 with an additional 3 lb. bowl. This allows me to do small or large batches, I suspect that one can polish bigger rocks in the UV 10, but I see some beautiful smaller slabs done by members here in the Lot-O.
geodehunter
Post by geodehunter on Oct 5, 2013 18:25:44 GMT -5
Thanks for all the help guy's I really appreciate it. 2 key factors did surface when reading the reply's. First was when John mentioned ceramic media. For me running 50/50 would work out perfect. Second, When grayfingers mentioned polishing bigger rocks. A lot of stone that I work with will run up to 6oz pieces. It looks like I might need the UV10 after all. I should mention that I do have a Lortone QT66 for running the first 2 stages of abrasive grits through. Once again thanks!!!
grizman
Member since July 2011
Post by grizman on Oct 5, 2013 20:05:18 GMT -5
I have the uv10 and it is great. I keep it pretty full of ceramic media so I can do as little or as much as I want at a time. Either are great, lots of folks swear by either. I am in total agreement here. I don't think either would be a mistake. The cost will be different though...
Post by Deleted on Oct 5, 2013 21:05:30 GMT -5
Greetings [geodehunter] firstly may i welcome you to RTH from the other side of the pond! Another consideration is how much noise they make, clearly the UV10 makes almost twice the racket of the Lot-O, if you do choose the UV make sure it's the UV Industrial with a blue stripe, otherwise it will wear-out pretty fast as they are made with inferior parts for polishing brass. Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from this monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
grayfingers
Post by grayfingers on Oct 6, 2013 6:56:22 GMT -5
Post by pghram on Oct 6, 2013 14:45:48 GMT -5
I have a raytech and hate it. I don't use it, I do everything rotary, so my comment is more general. It sounds like the UV10 would ultimately give more options on quantity & size with the use of additional media. More options is usually better in this hobby. Also, there is a tendency to go bigger & bigger as time goes on. So, if the cost is close, I would go with the option that was most versitile.
Rich
herchenx
Post by herchenx on Oct 6, 2013 18:21:41 GMT -5
One pain point about the uv10 is that you have to thread off the top wing nut to look at the progress where I see on the Lot-O you can just pop the lid.
Not a big deal but something to think about.
plumberinaz
Member since June 2013
Post by plumberinaz on Oct 6, 2013 19:14:03 GMT -5
Post by Hard Rock Cafe on Oct 6, 2013 22:19:37 GMT -5
You could run the UV without the lid or use a shower cap on it.
I have a UV18, which takes a lot of rock to keep fed.
