Post by jakesrocks on Oct 18, 2013 22:35:58 GMT -5
Not home built, but I received a couple of projects to see me through the winter. First is a vintage 8" Rocks Lapidary arbor. It's missing the hood and pan which I'm searching ebay for, but the bearings are free and quiet. Before I disassemble it, I'm gonna soda blast it down to bare metal. Next is the Poly arbor. Narrow Poly hood on one end, Wide Rock's hood on the other, with SC wheels that need dressing, but have a lot of life left in them. The bearings are free and quiet, so won't need to replace them.
Post by Fossilman on Oct 19, 2013 10:54:54 GMT -5
Don,do you have any buddies that press,cutand form steel? Shouldn't be to hard to make a hood for that..Thats a nice old piece of equipment too...Thumbs up
Post by jakesrocks on Oct 19, 2013 11:22:08 GMT -5
Hey Mike, I have 1/2 sheet of 1/8" aluminum in my shed. I'll lay out and cut everything and take it to a local sheet metal shop for bending and welding.
I'd rather find original parts to restore, but you do what you gotta do.
Post by jakesrocks on Oct 20, 2013 22:34:05 GMT -5
WOO HOO !! Scored another 8" Poly arbor on ebay. This one has already been restored.
Post by jakesrocks on Oct 25, 2013 16:31:23 GMT -5
Now this is what a Poly arbor is supposed to look like. This arrived this afternoon. I scored another vintage machine yesterday. An old Beacon Star arbor with hood and pan. It shipped today. I'll post pics when it gets here.
Post by phil on Oct 26, 2013 13:29:36 GMT -5
WOO HOO !! Scored another 8" Poly arbor on ebay. This one has already been restored. So you're the one who was bidding against me!
Post by jakesrocks on Oct 26, 2013 14:40:24 GMT -5
WOO HOO !! Scored another 8" Poly arbor on ebay. This one has already been restored. So you're the one who was bidding against me! It were I, the crazy sniper.
Post by 1dave on Oct 29, 2013 16:40:29 GMT -5
Wild idea . . . What about building a hood and shield out of three bread pans?
Post by phil on Oct 29, 2013 18:45:01 GMT -5
Old bicycle wheel cover is better and probably cheaper too! I've also used PVC el's.
Post by jakesrocks on Oct 29, 2013 18:57:01 GMT -5
Wild idea . . . What about building a hood and shield out of three bread pans? Dave, I'm an old retired sheet metal man with half a sheet of 1/8" aluminum in my shed. I'll lay out and cut everything, and take it to the local sheet metal shop for bending and welding.
Post by 1dave on Oct 29, 2013 19:24:49 GMT -5
"Dave, I'm an old retired sheet metal man with half a sheet of 1/8" aluminum in my shed. I'll lay out and cut everything, and take it to the local sheet metal shop for bending and welding."
With your background, that will turn out well!
Post by jakesrocks on Oct 29, 2013 22:48:40 GMT -5
WOO HOO !! The Beacon Star machine arrived today, and it's a beauty. Not gonna take much to restore it. Even the whole original water manifold is there and in good shape. I just have to dismantle the machine, soda blast the aluminum pan,frame and hood and spray it with green hammertone paint to make it look original. Wish I could find a NOS Beacon Star decal for it, but chances of finding one are slim to none. I'll post pics of the machine as it sits tomorrow.
Post by phil on Oct 30, 2013 15:43:24 GMT -5
You do any metal spinning?
Post by jakesrocks on Oct 30, 2013 20:27:40 GMT -5
You do any metal spinning? I have, but it's been about 40 years since I did any. Used to spin aluminum in a wood lathe.
Post by phil on Oct 30, 2013 21:57:06 GMT -5
OK. I needed a pan made, but not bad enough to make you go back....
Post by jakesrocks on Oct 30, 2013 22:05:03 GMT -5
OK. I needed a pan made, but not bad enough to make you go back.... Fat chance I would ever go back. I'm enjoying retirement too much. I still do a little sheet metal work for myself but don't have any of the large equipment needed.
Post by phil on Oct 31, 2013 12:13:16 GMT -5
Not the "go back" I meant, sorry.
Post by jakesrocks on Oct 31, 2013 12:35:10 GMT -5
No problem Phil. UPS just arrived with 2 brand new motors for the arbors I'm restoring. Now I just need a dry, low humidity day to soda blast the machines. Sure wish I had a climate controlled paint booth with filters and extractor fans.
Post by jakesrocks on Oct 31, 2013 14:15:44 GMT -5
Here's the Beacon Star 6" Economy Grinder that came a couple days ago. I hope to convert it to hold 5 - 1/2" wide convex diamond wheels. I'm also hoping that a heat gun will allow me to take the original glued on ID plate off without damaging it, so it can be put back on after soda blasting and painting the machine.
Post by jakesrocks on Oct 31, 2013 16:57:45 GMT -5
WOO HOO !! Just ordered 150 nylon spacer washers. 1/8" thick X 3/4" id X 1-1/8" od. These are going to be great for getting the spacing I want between wheels. I may order another 150, just to have them on hand for other projects.
