sealdaddy
Post by sealdaddy on Nov 1, 2013 17:53:00 GMT -5
NOBODY on the gemstone.smfforfree4 forum has a Clue~!! Uploaded with ImageShack.us
Post by Deleted on Nov 7, 2013 13:30:10 GMT -5
What tests have you done for yourself?
Streak on aporcelain tile?
Scratch with a knife?
Does it bubble with acid put on it?
Can you describe the area surrounded by green that looks druzy? Is there crystals in there?
Maybe a pic outdoors for faster shutter speed and sharper image is iin order?
Good luck with your quest!
sealdaddy
Post by sealdaddy on Nov 7, 2013 15:09:27 GMT -5
Thank you for answering, friend. Knife blade leaves metal behind...no scratch. Acid bubbles slightly. Yes, those are crystals I don't have any ceramic tile to do streak test...but I'm thinking it's a form of chrysoprase, although the green is a bit dark.
Your thoughts?
Post by Deleted on Nov 7, 2013 16:53:50 GMT -5
too hard to scratch but bubbles with acid is out of my league. What acid didya use?
Chrysoprase is nickel colorant chalcedony. Could be the green part, but wouldn't expect it to bubble.
This is pure free form thought speculation and not based on any real knowledge.
[start mental riff]
I am almost thinking copper ore based chalcedony. Red cuprite/black copper oxide/green malachite is a common color triad, to be harder than steel means it could be silicified into a "gem" form. Never heard of such an animal!
[end of mental riff]
I am not the right guy for this. Hoping Daniel or Mel or another genius here will offer guidance.
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Nov 7, 2013 17:16:48 GMT -5
looks like malachite running through matrix. I've seen similar stuff out of the dixie apex mine here in southern utah.
sealdaddy
Post by sealdaddy on Nov 8, 2013 12:17:18 GMT -5
It was hydrochloric acid, shotgunner. But Don....malachite is very soft. This stuff leaves metal from my knife blade, when I try to scratch it. It won't scratch, friend.
Post by Deleted on Nov 8, 2013 13:32:16 GMT -5
bubbles with hydrochloric acid, harder than steel.
Anybody?
Post by wireholic on Nov 8, 2013 13:41:59 GMT -5
Superman?
Post by wireholic on Nov 8, 2013 14:16:11 GMT -5
Sorry - couldn't help myself. Lack of sleep makes me punchy after a while. I meant kryptonite anyway
sealdaddy
Post by sealdaddy on Nov 9, 2013 11:50:26 GMT -5
But that's calcite. This stuff does Not scratch with a knife...but thanks~
Post by Deleted on Nov 9, 2013 13:26:23 GMT -5
sealdaddy - I have some "agate" here that is too hard to scratch with a knife but bubble with acid. I tried to polish it and areas of red (in my case maybe not yours) undercut. I put acid on it and the red areas bubble. Limestone in my stone is red and scratched with a knife. Is the bubbling in your all over or localized to one color? If it's one color try to scratch that color. Maybe you have a jasper/marble combo.
sealdaddy
Post by sealdaddy on Nov 9, 2013 13:39:44 GMT -5
It is the green that bubbles
Post by Deleted on Nov 10, 2013 21:32:53 GMT -5
ok, is the green soft enough to scratch with a knife blade?
sealdaddy
Post by sealdaddy on Nov 11, 2013 12:54:23 GMT -5
Right
rykk
Member since September 2011
Post by rykk on Nov 11, 2013 21:33:43 GMT -5
Looks like Parrot Wing Chrysocolla to me... Rick
sealdaddy
Post by sealdaddy on Nov 12, 2013 11:51:12 GMT -5
By Golly...I think you are Right~!! I had not know about that~
Thank You, friend~!!!
