Post by Lapidaryrough / Jack Cole on Dec 11, 2013 10:12:43 GMT -5
herchenx
Member since January 2012
Post by herchenx on Dec 11, 2013 11:23:07 GMT -5
Holy moly! Do you run those with grit and water or dry to just knock off matrix?
Post by Fossilman on Dec 11, 2013 11:51:42 GMT -5
Hey Jack.............Now that's a big one!!! Glad to see you back...Thumbs up
Post by Lapidaryrough / Jack Cole on Dec 11, 2013 11:59:30 GMT -5
John i run the tumblers same as the small 15 sizes / 2/3 - 3/4 full. then 1 Lb. grit for every 10 Lbs. rock.
Though i crush up old grinding wheels
for large pieces they last longer an i add 40/70 on the rough run with broken pieces.
then add water 2" below rock level run 3 days running.
and check the mud for the right fell, like tooth paste.
for the polish i use viking north model
VSV-45 lb size vibrator models size.
& the same in a double 6 ponder i have two viber-sonic.
only with polish no grit run in them.
Jack Cole
Post by Deleted on Dec 11, 2013 12:43:42 GMT -5
Post by Fossilman on Dec 11, 2013 13:48:39 GMT -5
Is it at your shop now? I got to get down there and see that!
Post by catmandewe on Dec 11, 2013 14:36:00 GMT -5
Now that is cool as hell!
Tony
Post by Donnie's Rocky Treasures on Dec 11, 2013 14:49:29 GMT -5
Hi Jack!!! Those are some serious tumblers!!!
Post by Lapidaryrough / Jack Cole on Dec 11, 2013 15:04:00 GMT -5
last year friend got me 9 fives of fire agate rough in Tuscon Az. ( Deer creek material ) I'm filling the 18 side barrel first. with 40/70 grit / just so i can read the material right!!! - YA i hear the voices 400 lbs well crush it too 80 grit in hours............
the other two are 12 & 10 side'd
Post by jamesp on Dec 11, 2013 17:09:21 GMT -5
About time some one got a real tumbler around here. Good gosh o mighty !
Post by quartz on Dec 11, 2013 20:23:56 GMT -5
Holy cow, that's a TUMBLER set.
Post by Deleted on Dec 12, 2013 0:49:30 GMT -5
last year friend got me 9 fives of fire agate rough in Tuscon Az. ( Deer creek material ) I'm filling the 18 side barrel first. with 40/70 grit / just so i can read the material right!!! - YA i hear the voices 400 lbs well crush it too 80 grit in hours............ the other two are 12 & 10 side'd 9 fives?
Post by Lapidaryrough / Jack Cole on Dec 12, 2013 2:27:36 GMT -5
last year friend got me 9 fives of fire agate rough in Tuscon Az. ( Deer creek material ) I'm filling the 18 side barrel first. with 40/70 grit / just so i can read the material right!!! - YA i hear the voices 400 lbs well crush it too 80 grit in hours............ the other two are 12 & 10 side'd 9 fives? yes ( nine fives ) Painters use them for paint, an to roll out of. i'm here to only to help others too push their count. ON there tread reads!
Post by Deleted on Dec 12, 2013 12:01:08 GMT -5
nine five gallon pails??
Post by Hard Rock Cafe on Dec 12, 2013 13:42:57 GMT -5
Those are impressive Jack! (and welcome back!)
How do you clean them out?
Post by Drummond Island Rocks on Dec 12, 2013 15:05:30 GMT -5
Great I am now officially suffering from tumbler envy. On the other hand I do not envy your weekly clean outs. I can barely handle washing and inspecting/sorting 40 pounds each week. Very impressive build and looks like it will last forever.
grizman
Member since July 2011
Post by grizman on Dec 12, 2013 15:36:46 GMT -5
WOWWWZERS! No other way of expressing my thoughts other than...WOWWWZERS !!
grayfingers
Member since November 2007
Post by grayfingers on Dec 12, 2013 19:40:16 GMT -5
Good to see you back, Jack! That is an awesome tumbler. Folks, I bought my Brazilian agates from lapidaryrough.com, VERY happy with them.
Bill
Post by Lapidaryrough / Jack Cole on Dec 12, 2013 19:56:44 GMT -5
i need too post the finish photos. adjustable legs were over 200 $$$, complete cost to build to much....it's home now it is in test run now, filled the barrels full of water to run wt. load.
Brazilian & fire agate next. for the real rock run. hatch opening is 6" x 6" so large material.
to clean rock out well the legs are high, so i can put screen lack under. farm duty motor so i can hose clean. engine hoist to pull barrels.
MrCoffee
Member since December 2005
Post by MrCoffee on Dec 17, 2013 22:38:24 GMT -5
I'm looking forward to seeing your photos of this machine, finished. Looks like you did a great job fabricating, just think of how it'll look with a powder-coated finish. A C40 (Lortone) is huge, but man it's tiny compared to this behemoth!
