Member is Online
Post by jamesp on Jan 9, 2014 10:46:50 GMT -5
Post by radio on Jan 9, 2014 10:58:57 GMT -5
It could be used for low strain applications I suppose. For bails, ring shanks, etc, one needs the strength of silver solder so the piece will not eventually break apart at the join. Silver soldering is like brazing and changes the molecular structure of the metals allowing the solder to penetrate both pieces being joined and is as strong as the metal it's self I have repaired many rings and pendants that someone had repaired before using a low temp solder and it just doesn't hold up well.
Member is Online
Post by jamesp on Jan 9, 2014 13:33:21 GMT -5
Perfect. I am thankful of that answer. I have looked at silver joints and there is no way to tell where the solder ends and starts. I knew you were not allowed any short cuts in the dang solder department. Deviants not allowed. Now depressed
Post by 1dave on Jan 9, 2014 14:44:22 GMT -5
Perfect. I am thankful of that answer. I have looked at silver joints and there is no way to tell where the solder ends and starts. I knew you were not allowed any short cuts in the dang solder department. Deviants not allowed. Now depressed Always use the proper tool for each application. Never use a screw driver for a chisel. I'm so glad my shop teacher taught me that, otherwise I never would have thought of it when a chisel wasn't at hand!
Post by deb193redux on Jan 9, 2014 14:49:50 GMT -5
when tin solder is used, the piece cannot legally be stamped .925 sterling.
Member is Online
Post by jamesp on Jan 9, 2014 15:23:13 GMT -5
Perfect. I am thankful of that answer. I have looked at silver joints and there is no way to tell where the solder ends and starts. I knew you were not allowed any short cuts in the dang solder department. Deviants not allowed. Now depressed Always use the proper tool for each application. Never use a screw driver for a chisel. I'm so glad my shop teacher taught me that, otherwise I never would have thought of it when a chisel wasn't at hand! Yes sir.
Member is Online
Post by jamesp on Jan 9, 2014 15:24:07 GMT -5
when tin solder is used, the piece cannot legally be stamped .925 sterling. Never thought of that. Great point deb193.
Post by 1dave on Jan 9, 2014 17:09:16 GMT -5
jamesp Of course I used the screwdriver for a chisel. If I'm working sterling I use the SS, otherwise, who cares.
Post by radio on Jan 9, 2014 18:01:51 GMT -5
Perfect. I am thankful of that answer. I have looked at silver joints and there is no way to tell where the solder ends and starts. I knew you were not allowed any short cuts in the dang solder department. Deviants not allowed. Now depressed Always use the proper tool for each application. Never use a screw driver for a chisel. I'm so glad my shop teacher taught me that, otherwise I never would have thought of it when a chisel wasn't at hand! On another forum I frequent, my sig line is: "A good knife is the most expensive pry bar you will ever own!"
Member is Online
Post by jamesp on Jan 9, 2014 18:42:24 GMT -5
jamesp Of course I used the screwdriver for a chisel. If I'm working sterling I use the SS, otherwise, who cares. That 4% silver/96% tin is great for the other metals. I hear you. I figured you use a screw driver as a chisel. Deviance is a strength. You would know i do cause the metal is rammed 3 inches up into the handle Radio too. My shop teacher was a bad dude with a paddle he like to use. I have seen chips fly off that thing more than once.
Post by 1dave on Jan 10, 2014 10:00:33 GMT -5
Radio too. My shop teacher was a bad dude with a paddle he like to use. I have seen chips fly off that thing more than once. My shop teacher had one of those with holes drilled in it so air wouldn't slow it down! a "friend" and I packed our lunches and ate in the playground rather than eat in the lunch room. One day it rained so we sneaked thru a window into the woodwork shop. My "friend" decided he didn't like his peanut butter and jelly sandwich, so he squished it in a wood vise. Of course someone saw us crawl through the window, and we were called to stand before the class, bend over and grab the ankles. I wasn't going to rat him out and took the first blows. "Friend" swung forward to avoid the hit. Teacher instantly knew who the real culprit was and that paddle flew!
Member is Online
Post by jamesp on Jan 10, 2014 11:05:03 GMT -5
Only a shop teacher would dream up an aerodynamic paddle. Too funny/too painful.
A time when respect was taught.
Post by 1dave on Jan 10, 2014 11:11:09 GMT -5
Only a shop teacher would dream up an aerodynamic paddle. Too funny/too painful. A time when respect was taught. And the lack of that is why our schools are failing!
Member is Online
Post by jamesp on Jan 10, 2014 11:17:01 GMT -5
Gotta have respect. Easiest way to learn is to humbly respect your teacher. Basic. Program yourself to respect your teachers and the highway of knowledge will fill your brain.
I am to lazy and stupid to buck my teacher.
Post by rockjunquie on Jan 10, 2014 11:58:32 GMT -5
I remember swats! I was a really rotten kid in school. I wouldn't doubt it if I held some kind of record for swats. Every time I smiled or laughed, I'd get more. It truly was no deterrent for me.
Member is Online
Post by jamesp on Jan 10, 2014 13:16:25 GMT -5
The rebels can often lead the pack when they open the door to the real world.
Post by Rockoonz on Jan 10, 2014 15:38:44 GMT -5
From solder to paddles, yep those aerodynamic paddles sure left an interesting design on the buttocks. The solder could come in handy with some types of art metal projects for a little added reinforcement of mechanical joints.
Lee #2
Member is Online
Post by jamesp on Jan 10, 2014 17:21:02 GMT -5
From solder to paddles, yep those aerodynamic paddles sure left an interesting design on the buttocks. The solder could come in handy with some types of art metal projects for a little added reinforcement of mechanical joints. Lee #2 I get on to my wife talking in circles. Best hide this thread or keep my mouth shut. LOL.
Post by 1dave on Jan 10, 2014 17:50:28 GMT -5
Hey, WE are wheels!
Member is Online
Post by jamesp on Jan 10, 2014 20:14:44 GMT -5
It is good. I don't know if that will fly in her eyes...too bad so sad. haha
