Henry
60/90
Mar 2, 2014 21:49:47 GMT -5
Post by Henry on Mar 2, 2014 21:49:47 GMT -5
Hello again. This may have been covered here before, but I was curious if you can stack 60/90 grit. In other words, if the stones weren't sufficiently smoothed the first time around, can you just add more 60/90 grit instead of dumping the slurry and starting over? If so, how many cycles can you do this for?
Many thanks
Henry
Mar 3, 2014 3:15:27 GMT -5
Post by Deleted on Mar 3, 2014 3:15:27 GMT -5
Greetings [sanjuro66] Henry yes you can add extra grit to the barrel for up to 3 times, usually adding 1 Tablespoonfull per time, but it slows the action down. Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from this monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
60/90
Mar 3, 2014 9:13:19 GMT -5
Post by pghram on Mar 3, 2014 9:13:19 GMT -5
I would hesitate to give certain number of times, I would judge by the thickness of the slurry. If it’s too thick it will slow down the grinding. In that case you could pour some off & add more water & grit. I run ten day cycles & then start fresh.
Rich
