azgnoinc
Member since March 2014
Post by azgnoinc on Mar 27, 2014 23:13:39 GMT -5
I live a couple miles from a plant that produces titanium dioxide and have pretty easy access to getting my hands on some for free, but being a newbie to tumbling - can I use this for a pre-polish or for a final polish? I plan on tumbling a lot of agate & jasper, so I'm wondering about those specifically and what should my polish cycle run - I'm assuming 10 days or so provided everything else has done it's job well up to that point? Thanks in advance....Gene
stephent
Post by stephent on Mar 28, 2014 0:32:18 GMT -5
Well... most titanium dioxide is used in paints or makeup...so it's really fine.. like 1 to 2 microns. Which puts it way into the "polish" stages. Like a 4000 to 6000+ grit or so.. depending on manufacturer. Polish length time is where you are "more then happy with the finish" number of days. Week to two.. check barrel after a week...then every day or two. After a while you might start getting chipped edges..depending on stone size and fill.
Post by johnjsgems on Mar 30, 2014 14:13:37 GMT -5
I've heard it is the polish used in Lortone kits. I tried it with Montana agates and it worked as well as cerium.
azgnoinc
Post by azgnoinc on Mar 30, 2014 18:45:34 GMT -5
Thank you both Stephen and John, think I'll get some as it's free and give it a shot sometime.
bruceb
Member since August 2013
Post by bruceb on Apr 29, 2014 23:47:22 GMT -5
Sorry to post this a month late but I just saw this post. Titanium dioxide can come as water soluble or Oil soluble. The stuff I use to make candles is the oil soluble so be sure what you have will work in water and not just cake up. Bruce
Post by Rockoonz on May 3, 2014 12:27:02 GMT -5
I just saw it too. TiO2 is used as a white pigment in the rubber and plastics industry, and judging by how hard it is to get off the hands if I don't wear gloves, it could be very difficult to remove from rocks with pits. Possibly a couple drops of dish soap in the water would help.
