mikeinsjc
Member since June 2010
Post by mikeinsjc on Apr 14, 2014 10:27:18 GMT -5
In my tumbling mix are a lot of slices, 1-3" across. I tumble in a rotary for two weeks, then go to a 50 lb Diamond Pacific vibrating tumbler. My steps in the vibe are; 220 for 24 hrs. 400 for 24 hrs. 600 for 24 hrs. 800 for 48 hrs. TXP for 24 hrs.
Round or near-round stones come out fine. For the slabs or any stone that has the slightest flat surface, that surface is dull. I run 3/8 x 3/4" ceramic pellets, and have run up to 50% pellets by volume, and the flats are still dull. Does anyone have any specific experience in dealing with this problem?
Post by deb193redux on Apr 14, 2014 12:19:58 GMT -5
I would let the slabs go longer at 220. the amount of energy to round an edge is small compared to the amount of energy to level a plane. If you have enough pellets to keep slabs from sticking face-to-face and riding together, they should polish if the rock can take a polish. I often did slabbetts in my Lot-O
snowdog
RIP David Fildes, aka: snowdog
Post by snowdog on Apr 14, 2014 15:25:08 GMT -5
About all I do is slabs in a #50 vib --same as what Daniel said above --I usually do at least 3 days ,maybe 5 in 220, then I jump to 600 for another 3-5 days then 1000-1200 for another 3-5 days then polish for maybe up to 7 days -- the flats just take a lot longer than the corners do
mikeinsjc
Post by mikeinsjc on Apr 14, 2014 16:51:55 GMT -5
snowdog, what would you estimate your ratio is, rocks to pellets? Do you use ceramic? If so, what size?
snowdog
Post by snowdog on Apr 15, 2014 3:25:17 GMT -5
probably 60/40 (60 being ceramic) and they probably started out the size you mentioned but some have wore down over the years and are smaller--- I dump the whole batch on a screen I have to wash them and the little crums do fall thu so no tiny pieces are in there ( screen holes are @ pencil lead size) but every size from there on up is. just last summer I started a new batch for polish so they are all 3/8's x 3/4 ( haven't wore down much yet ) was thinking about the % as I was typing this and it may be even lower 70/30 or 80/20 as I leave the ceramic in the tumbler all the time then add slabs after I turn it on -- I like for them to "swim" around and when they get close/tight to each other I quit putting them in --but do different size batches from 20 to 50 # -- I also don't worry about 2-3-4 slabs sticking together as long as they have some slurry between them (will come apart when they get washed before the next size grit)
Post by jamesp on Apr 15, 2014 7:52:12 GMT -5
I crush smalls of the slab material. 70% slabs and 30% smalls, maybe 80/20. The slabs spend a lot of time stuck together...The smalls get between them. Typical mass cut slabs that were tumbled. Did about 50 pounds of them in 16 pound rotary barrel. 30/60 then 220 then 500 and finally polish. a week each.
mikeinsjc
Post by mikeinsjc on May 9, 2014 9:28:42 GMT -5
snowdog, it seems the amount of time you need to let the slablets run in the vibe is approaching the times you would run them in a rotary,negating the time savings a vibe offers. Do they polish ok in a rotary? Have you tried it?
Post by deb193redux on May 14, 2014 8:12:52 GMT -5
the times he gives are in days. in a rotary that 3-5 days become 3-5 weeks or at least 3-5 5-day sets. I am not seeing the time comparison you make.
the edges will also get much thinner in a rotary.
