ivan
Member since March 2014
Post by ivan on May 12, 2014 17:51:35 GMT -5
Post by jakesrocks on May 12, 2014 18:41:50 GMT -5
Clicked the link. Got the message, Sorry, this page does not exist.
I've used cut off bamboo skewers to dop small cabs before. Never tried it with anything large.
Post by DirtCleaner on May 12, 2014 20:13:23 GMT -5
On Photobucket open up your photo and on the far right of the page look for the direct link. Copy it and paste it in your post. You can make it work. And once you do go ahead and post tons.
Post by mohs on May 12, 2014 20:22:28 GMT -5
bamboo is great for satay's also dop'n & satay'n all on one stick life's good! mostly
Post by DirtCleaner on May 12, 2014 20:28:51 GMT -5
There may be better photo tutorials on the site but after you put your link to the image on go towards the top and look for the little photograph symbol, hit it and follow the directions.
ivan
Post by ivan on May 12, 2014 21:26:58 GMT -5
ivan
Post by ivan on May 12, 2014 21:38:23 GMT -5
First time photo success, I think? Have a small grove here in central Pa. Found some of the small sections of bamboo dried, some not and gathered it up. When I researched it I wanted to see if I could get what they called a timber bamboo for tomato stakes, etc. It has survived, after 15+ years some of it is 1"+ diameter. Very woody tough stuff. An idea light up I thought why not dop sticks. Since I believe there have been all kinds of things used over time. If you use a tapered reamer 45 or 30 degree you can put a cone end on it to fit your stone. Thought I'd share this with the forum family and get your thoughts. Hope this helps? Ivan
ivan
Post by ivan on May 12, 2014 21:45:25 GMT -5
There may be better photo tutorials on the site but after you put your link to the image on go towards the top and look for the little photograph symbol, hit it and follow the directions. I'll have to look into that further. I looked into adding an attachment but something about forum space. I really don't fault the tutorials, its just that I just don't get it for awhile. I'm half way there. I'll look for that photograph symbol and see if I can sort it out. Thank you very much! Ivan
ash
Prairieville, Louisiana
Member since July 2012
Post by ash on May 12, 2014 21:50:44 GMT -5
Ivan, I clicked on IMG on the right hand side and it copied, then pasted here. Hope that helps
deserthound
Member since December 2013
Post by deserthound on May 12, 2014 22:53:54 GMT -5
looks like it works great, i had thought about that a lso but ended up using some wood dowel material given to me..whatever works..thanks for sharing
ivan
Post by ivan on May 15, 2014 22:20:41 GMT -5
Thank you for your help & David for getting the photo set up. Will have to see if I can put it all together next time Ivan
