gemfeller
Member since June 2011
Post by gemfeller on May 14, 2014 21:35:50 GMT -5
Does anyone recognize the source of this water-level agate? I know where it's from but I wonder if anyone here does. It may be a more common type than I think so I'm prepared to be "educated."
Post by Fossilman on May 15, 2014 12:05:18 GMT -5
If I could see the outer agate.....Could be an odd Montana agate...Have seen a few with total waterlines running through them..
gemfeller
Post by gemfeller on May 15, 2014 13:09:14 GMT -5
Good eye! Right the first time. I deliberately showed only the cut face because the outer shape would give the source away. I've seen a lot of Montana, some including partial water-level pattern, but this is the only one like this to come my way. As far as I can tell it contains no dendrites.
70karmann
Member since February 2011
Post by 70karmann on May 15, 2014 13:44:57 GMT -5
I believe this is a Montana Agate. I have collected many with the same pattern. Collected on the Yellowstone River. Known as layered agate.
gemfeller
Post by gemfeller on May 15, 2014 17:11:17 GMT -5
Yes, it's Montana. Fossilman nailed in in the first response. I've seen quite a bit of Montana but not this type. Live and learn and learn and learn...
Post by Fossilman on May 15, 2014 19:15:08 GMT -5
I'm headed to Montana to get some Montana agate hunting out of the Yellowstone River,between Livingston and Billings...Be there in June....
Post by Fossilman on May 17, 2014 16:41:36 GMT -5
Here is the one and only waterline Montana agate I have/I have cut over 100 pounds of Montana's and only one out of the whole bunch.....
Mark K
Member since April 2012
Post by Mark K on May 20, 2014 14:56:28 GMT -5
I cut a piece just like that last night. I find way too much of it.
