Post by jamesp on May 17, 2014 10:04:07 GMT -5
Leaking barrels for 4 months have coarse ground guts out of bearing.ha Notice right side bearing is eaten out and shaft is no longer centered in hole. It ran w/little friction but sounded like a donkey screaming. Welcome to the south.
stephent
Member since March 2014
Post by stephent on May 17, 2014 10:47:27 GMT -5
Well...poo-poo. But rebuild-able. How's the pulleys holding up?
Post by jamesp on May 17, 2014 10:57:08 GMT -5
All is fine stephant. One bad bearing is all. The tumbler shafts slope down toward the end roller. All the slurry followed the shafts and visited the bearings on the downhill side. Easy to change side. A $16 bearing (1.5 inch shaft). Slurry has been getting on those bearings for 2 years and I just hose them down. The big barrels leak over a 5-10 day period to a nice thick slurry consistency. So I just let em roll.
stephent
Post by stephent on May 17, 2014 11:19:01 GMT -5
Maybe a large plastic washer siliconed just before the bearing would keep some of the slurry off the seals?
Post by jamesp on May 17, 2014 12:35:30 GMT -5
Great idea stephant. These drip rings slide down a kayak paddle to keep your hands dry when paddling
tkvancil
Member since September 2011
Post by tkvancil on May 17, 2014 17:39:42 GMT -5
No doubt you'll have it repaired and running like a champ in no time. Stephent's washer idea is a good one.
Post by jamesp on May 17, 2014 19:12:30 GMT -5
No doubt you'll have it repaired and running like a champ in no time. Stephent's washer idea is a good one. It was interesting to watch them run in grit tk.
Post by Starguy on May 17, 2014 20:38:50 GMT -5
Warm the rocks and use hot water when charging the barrel. It will help keep pressure from building up and causing leaks. Are you tumbling obsidian or glass? They also tend to make barrels leak.
Post by quartz on May 17, 2014 23:09:50 GMT -5
Haven't seen a bearing do that since the sawmill, slick shaft collar idea. Where do you get that big a bearing that cheap??? Larry
Post by jamesp on May 18, 2014 0:55:23 GMT -5
Post by jamesp on May 18, 2014 0:57:51 GMT -5
Warm the rocks and use hot water when charging the barrel. It will help keep pressure from building up and causing leaks. Are you tumbling obsidian or glass? They also tend to make barrels leak. It is simply a leak starguy. Home made barrel. Yes, worse when gaseous, but leaks either way.
