Post by Deleted on May 20, 2014 17:25:03 GMT -5
Dad thought all my tumbling problems where because of weight, would this work small amout of rocks and the rest plastic bbs?
that's just some of the used bbs I was gonna use more to make it 3/4th full.....to reduce the weight if that's why my barrel wont keep spinning
Post by Deleted on May 20, 2014 17:35:08 GMT -5
Im gonna wait for advice cause I am out of coarse grit, just fine grit and some pre polish and polish......its driving me crazy not tumbling, I thought id just see what happened doing it like this with fine grit....but its not worth losing more grit and screwing up my rocks if it would be a bad idea
Post by Deleted on May 20, 2014 17:49:19 GMT -5
Im not sure if this would make it start spinning again continuously basically, I don't want to beat my tumbler like a dead horse if that's what it is
Post by iant on May 21, 2014 1:25:15 GMT -5
If those rocks are still at the stage requiring course grit, I'd wait until you have some available or you will just be wasting your finer grit. Also I have found if I don't fill a barrel to about 2/3 full of rocks, I get a sliding action in the barrel rather than tumbling, which is not what you want. I can't help thinking that might happen here with your lighter plastic BBs. Hope that is some help, probably not what you want to hear though!
Regards Ian
Post by rocking&earthing on May 21, 2014 2:22:57 GMT -5
Order your Grit at the Rock Shed, I was absolutely amazed on how fast they deliever. Ordered on a Sunday night late, recieved on Wednesday.
1nickthegreek
Member since February 2014
Post by 1nickthegreek on May 21, 2014 3:39:23 GMT -5
Dont waste your fine grit, send me your address and I will send you a bag of coarse grit....use just general junk gravel as filler and just dont load it too heavy ya know?!?!?!
Post by catmandewe on May 21, 2014 10:01:25 GMT -5
I would say you need to look at tightening up your belt or get a new belt if you are slipping, the weight of the barrel should be of little consequence.
Tony
Post by Deleted on May 21, 2014 16:12:20 GMT -5
Thanks everyone, well I just managed to get the belt off about to attempt to replace it......I accidently took one of the screws onthe outside all the way out of the motor and the frame I hope I didn't mess anything up, I got it screwed back in I think...I took a pic of this though....does it look normal?
Post by Deleted on May 21, 2014 17:53:32 GMT -5
I may have fixed it, not sure I replaced the belt......those orings where actually belts....I stripped another screw doing it but I noticed that it has a flat head option...so ill still be able to adjust it I think.....I gripped the turning part that the barrel sits on and it wouldn't stop or slip.........tomorrow im gonna put in enough rocks to fill to 3/4th again just with water to see how it turns for a day before I worry about grit......sound smart? just want to make sure shes running again with just water
1nickthegreek
Post by 1nickthegreek on May 21, 2014 23:07:27 GMT -5
I may have fixed it, not sure I replaced the belt......those orings where actually belts... .I stripped another screw doing it but I noticed that it has a flat head option...so ill still be able to adjust it I think.....I gripped the turning part that the barrel sits on and it wouldn't stop or slip.........tomorrow im gonna put in enough rocks to fill to 3/4th again just with water to see how it turns for a day before I worry about grit......sound smart? just want to make sure shes running again with just water Yeah, the screws are absolute junk on the HF tumblers, I just put decent machine screws in mine as soon as I took them out cos the holes all stripped when I was putting em back in LOL
Post by catmandewe on May 21, 2014 23:18:13 GMT -5
You should be tumbling soon!
Tony
Post by Deleted on May 22, 2014 15:41:43 GMT -5
Thanks tony and nick, I certainly hope I'm back to tumbling soon
1nickthegreek
Post by 1nickthegreek on May 22, 2014 17:20:54 GMT -5
Just use ordinary crushed gravel as filler if you need it, those bb's will just float and give you pretty much no benefit....you want a sliding action remember, not a banging thumping action, get the slurry nice and thick and you'll be off n rolling!!!!!
1nickthegreek
Post by 1nickthegreek on May 22, 2014 17:23:43 GMT -5
Thanks tony and nick, I certainly hope I'm back to tumbling soon Happy that I could be of service, let me know on the grit, I still have 10 or 20 pounds of 60/90 that I dont use a lot of since I only rotary til I get some shape and then they go in the vibe at 220, 600, AOX, and then cerium LOL
Post by Deleted on May 22, 2014 17:27:16 GMT -5
Thanks buddy im about to do a test run now i think i got the belt almost perfect
