michele57
Member since May 2014
Post by michele57 on May 30, 2014 10:58:29 GMT -5
I am only on day 4 of stage one and just checked my stones, This is my 1st time with 3 moh and I found some pieces to small 1/8 inch and others nearly half and less. What am I doing wrong in this tumbling process. Thanks Michele
Post by deb193redux on May 30, 2014 11:00:01 GMT -5
Tumbling such soft material is almost impossible. You might be able to get somewhere with 1 day in rotary, and then move to medium grit in a vibe.
Post by Toad on May 30, 2014 12:10:16 GMT -5
As Daniel said, way soft. What grit did you start with?
stephent
Member since March 2014
Post by stephent on May 30, 2014 12:44:32 GMT -5
Stage one 60-90 grit looks like a no-no to me.. I would start those at a graded 220 grit and even then watch them close. Fill up to 3/4--85% full with lots of plastic media...I would think ceramic media might even be a bit hard on the softer stones. And then again that soft may never be able to rotary tumble...but filling to nearly full (1/2 full of stones) the reswt with plastic media and starting with finer grit will give ya at least a shot at doing it. Last batch of rough quartz-ish stuff (but mohs of 6.5 to 7) I started was with 9 days of 120/220 (one grit recharge at 5 days) after roughing to shape with my whizzer grinder....no 60-90 stage at all. I'm about to give up totally on using 60-90 grit in my rotary tumbler. Even Agates very roughly pre-shaped came out lookin good with an almost double dose and time of 120-220 grit. Softer stones would be even less time.
Post by johnjsgems on May 30, 2014 13:32:51 GMT -5
Take a pocket knife and try to scratch your rocks. If they scratch you won't have much luck in a rotary tumbler. Those are both soft stones. I know of only one lepidolite mine where the material is mixed with Quartz (Thursday Mine) and may tumble OK.
gemfeller
Member since June 2011
Post by gemfeller on May 30, 2014 15:00:07 GMT -5
Both minerals have easy cleavage planes which means they'll split apart with a certain level of impact. Lepidolite is a form of mica and calcite has three directions of perfect cleavage. I think your problems may be more related to that than their hardness, but soft minerals/rocks are often hard to tumble-polish.
