Post by rockjunquie on May 30, 2014 23:03:42 GMT -5
I know this is wrapped, but I am asking about the cab. It is certainly azurite, but I am wondering if anyone can tell me the location and if it is malachite or chrysocolla in it. Is the picture good enough to tell? I took it in the diningroom under the halogens. I've done a little research and I am thinking it could bluebird azurite. (?) This is my first azurite. I picked a small, beat up corner to try it out. It surprised me how solid and hard it is considering how crumbly it looks. It is heavy for its size, too. It was actually pretty easy to cab, but the surface isn't exactly smooth. Is this something that would need to be stabilized? Thanks in advance. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) ![](http://www.telaformosa.com/pics/RTH/5-18-14/IMG_7534.JPG)
zarguy
Member since December 2005
Post by zarguy on Jun 1, 2014 0:23:06 GMT -5
Tela, No picture showed up. Try it again. Lynn
Post by rockjunquie on Jun 1, 2014 11:35:51 GMT -5
Tela, No picture showed up. Try it again. Lynn I guess my server was down when you looked. It appears fine for me.
Post by mohs on Jun 1, 2014 12:33:04 GMT -5
I have a slab of stabilized azurite Haven’t worked any yet & have never worked a stabilized slab I suppose it will work up fine
My azurite is in white matrix…mostly
Nice looking pendant
Post by washingtonrocks on Jun 1, 2014 16:05:50 GMT -5
Hard to say where it comes from since copper minerals can take on so many different looks. I would say that, from your picture alone, it looks like Azurite with Chrysocolla and the black areas are probably Tenorite. Amazing stone and awesome job on the wrap!
Deb/nyllynn
Deb & Jim
Member since April 2009
Post by Deb/nyllynn on Jun 18, 2014 14:06:34 GMT -5
I agree, Azurite, Chrysocolla and tenorite. Just got a book on rocks and minerals put out by the Smithsonian. it says that Azurite is the main mineral in Lapis and gives it the blue color. Great book... ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
cutiepie
Member since July 2014
Post by cutiepie on Jul 1, 2014 22:22:53 GMT -5
I agree azurite /chrysocolla. It could be from most any copper mine. I've seen very similar from Inspiration, Ray and even Bisbee. I've had bad luck with this type of stone, even stabilized. If this piece is not stabilized you've got some great stuff.
gemfeller
Member since June 2011
Post by gemfeller on Jul 1, 2014 22:57:42 GMT -5
I agree, Azurite, Chrysocolla and tenorite. Just got a book on rocks and minerals put out by the Smithsonian. it says that Azurite is the main mineral in Lapis and gives it the blue color. Great book... ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I hate to be picky but I'll bet if you double-check your book it'll say lazurite, not azurite. It's very easy to confuse the two based on the similarity of the names but they're two entirely different minerals: no copper in lazurite. Lapis Lazuli is a rock, not a mineral. Its make-up can vary a lot but the main minerals usually found in it are: lazurite (25% to 40%), a feldspathoid silicate mineral; calcite (white), sodalite (blue), and pyrite (metallic yellow). Other possible constituents: augite; diopside; enstatite; mica; hauynite; hornblende, and nosean. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
