markinohio
Member since June 2014
Post by markinohio on Jun 13, 2014 18:18:49 GMT -5
Folks,
Does filling pits and cracks with CA help any for grit carry over? Or is this a waste of time?
PS -Don't forget to call your Fathers this Sunday!
Post by quartz on Jun 13, 2014 23:18:08 GMT -5
CA is somewhat water soluble, doesn't work well. The best way to get stuck fingers to come apart is to soak them in water.
tkvancil
Member since September 2011
Post by tkvancil on Jun 13, 2014 23:53:07 GMT -5
I have tried it, doesn't hold up in a tumbler. Not worth the time. IMHO
Post by Deleted on Jun 14, 2014 2:32:59 GMT -5
The main problem with any filler is that it will be much softer than the stone, and the grit will cut away/undercut it. CA can be used thinned to help stabilize soft/porous material like chalk turquoise, but I agree with the others that it won't do as a filler. If you absolutely must fill a crack or void, then you might want to try doing so after the stone has finished tumbling, then sand flat with a piece of superfine (10k grit or so) automotive wet sandpaper and polish with something like Zam.
markinohio
Post by markinohio on Jun 14, 2014 17:39:24 GMT -5
Thanks folks.
