Post by radio on Jun 15, 2014 16:20:49 GMT -5
I need a good vise/clamp for coin cutting (piercing) and this one is perfect, but I can't find anything remotely like it on the internet. It would help if I knew the correct name or terminology. Do any of you know what it is called? The vertical handle at the rear actuates the clamp and would be perfect for piercing!
Post by phil on Jun 15, 2014 16:23:22 GMT -5
It's a woodworkers bench clamp. sometimes called a bench dog. Take the pic to any woodworkers supply house and ask them. Not cheap.
Post by radio on Jun 15, 2014 16:29:47 GMT -5
It's a woodworkers bench clamp. sometimes called a bench dog. Take the pic to any woodworkers supply house and ask them. Not cheap. That's what I thought too, but a Google search turned up nothing resembling this thing. I even pulled up Grizzly tool catalog and can find dogs of different types, but nothing like this
Post by jamesp on Jun 15, 2014 16:30:41 GMT -5
Also a welder's production jig clamp. Adjust it with screw and then tighten lock nut.
Post by phil on Jun 15, 2014 16:30:48 GMT -5
Take it to a wood workers supply house....
Post by Deleted on Jun 15, 2014 16:32:58 GMT -5
Looks homemade to me.theres gotta be someone on here that can build that.im thinkin jamesp.for he is a master of homebrew engineering. Dave
Post by radio on Jun 15, 2014 16:43:40 GMT -5
Doh! toggle clamp! Not perzactly like in the pic I posted, but I can make one work
Post by jakesrocks on Jun 15, 2014 16:44:18 GMT -5
Post by radio on Jun 15, 2014 17:51:20 GMT -5
You guys know of someone who could modify one to be like this?
Post by jakesrocks on Jun 15, 2014 18:15:33 GMT -5
It wouldn't be hard for you to modify one if you have a power drill. Make the jaws out of oak or maple. The jaws close parallel on this type of clamp. Just cut your bottom jaw out of the same piece of wood that you mount the clamp to. The top jaw is the only one that will move. Just drill two holes through the top jaw an inch or so apart. Counterbore the holes from the bottom to hide your bolt heads. Use one nut above the top jaw, and a nut above and below the movable metal jaw. Make adjustments by loosening and adjusting the nuts at the top jaw.
Post by Rockoonz on Jun 16, 2014 1:25:49 GMT -5
agatemaggot
Member since August 2006
Post by agatemaggot on Jun 16, 2014 2:05:56 GMT -5
WE use that type of clamp in lifting fixtures in the Blacksmith shop where I work. They are called Destaco clamps I believe.
Try Googling that.
Harley
Post by phil on Jun 16, 2014 12:16:40 GMT -5
Post by jakesrocks on Jun 16, 2014 12:48:19 GMT -5
The vertical bench clamp is sold out, and no longer being manufactured. It's a shame too. It would have been ideal for pierced work.
Post by phil on Jun 16, 2014 16:23:48 GMT -5
Bummer. But I saw lots of others there that could be adapted fairly easily.
Post by 1dave on Jun 16, 2014 22:03:11 GMT -5
Post by Rockoonz on Jun 17, 2014 0:02:16 GMT -5
Rockler sure does like money. I got a $20.00 groupon for $10.00 and I still could have purchased the same stuff somewhere else for less.
mibeachrocks
Member since September 2013
Post by mibeachrocks on Jun 17, 2014 8:46:40 GMT -5
harbor freight has them really cheap.
