sheltie
Member since January 2012
Post by sheltie on Jun 19, 2014 16:24:24 GMT -5
In mid December, I decided to clean my saw to get it ready for when the weather turned warmer. Just by bad fortune, I got sick right after the clean up. For several months after that I was unable to do anything so I had a clean saw. A little over a moth ago it looked like I would be able to resume slabbing on a very limited basis. Unfortunately, the day before I intended to fill the tank, my health decided it wasn't ready yet.
To make a long story shorter, I'm still not ready to start slabbing again but there may be light at the end of the tunnel. My question is, how long can oil be stored in the saw before it goes "bad" (if it ever does)? Even if I only get one more day that I'm able to slab again, I'd like to be ready. All I need to do is add the oil.
Post by phil on Jun 19, 2014 16:53:52 GMT -5
Mineral oil? forever.
Post by Deleted on Jun 19, 2014 17:02:38 GMT -5
As long as it is not any type of food grade oil,I would think forever as well
Post by DirtCleaner on Jun 19, 2014 22:06:46 GMT -5
Mineral oil has a VERY long shelf life. Hope you get the saw ready and once clamped in let the saw do the work. As long as it is an auto feed of any type. Good luck!
Post by Rockoonz on Jun 19, 2014 22:52:57 GMT -5
Good that it's clean, I have noticed that when the saw has been stored for a long time with dirty oil the rock snot tends to settle to the bottom and petrify.
Post by catmandewe on Jun 20, 2014 2:04:44 GMT -5
Mineral oil will store for years. The vegetable oil kind will spoil in the heat.
Hope you get to cut soon my friend................Tony
sheltie
Post by sheltie on Jun 20, 2014 8:30:56 GMT -5
Mineral oil will store for years. The vegetable oil kind will spoil in the heat. Hope you get to cut soon my friend................Tony Me, too, Tony. That rough you sent is lined up and ready to go! Denny
Mark K
Member since April 2012
Post by Mark K on Jun 20, 2014 22:20:52 GMT -5
Good that it's clean, I have noticed that when the saw has been stored for a long time with dirty oil the rock snot tends to settle to the bottom and petrify. Yes, but at that point, often you can get underneath it and peel it out in one or two big chunks with less waste of oil. I have done this before and the crud was almost like a rubber/clay. Once the putty knife got under it, it was a cake walk.
Post by Rockoonz on Jun 20, 2014 22:30:30 GMT -5
Mark K No, I'm talking more than a week or so, I like the silly putty too. I'm talking jackhammer petrified. I'm not sure how long it takes since all the saws I have experienced this with were purchased that way.
