jerrys
Member since February 2014
Post by jerrys on Jul 19, 2014 9:41:06 GMT -5
How does one polish 6" x 6" slabs of UT septarian nodules? Normally, I would use the vibrating laps with grit. I have concern the grit will cause undercutting. How will the calcite handle the heat of high speed dry sanding?
donkeyrokman
Member since June 2014
Post by donkeyrokman on Jul 19, 2014 10:49:02 GMT -5
The big problem is that you have three different hardness levels: Calcite Limestone Aragonite
Undercutting is a real concern. Plus, if you have any crystal vugs, it's super easy to pick up bits of crystal and scrape them across the surface, creating more problems.
I use a pneumatic, water-fed die grinder with diamond polishing pads, and that makes fast work of Septarians, but not too many folks have access to that kind of equipment.
I would normally suggest asking Loy Crapo from the Bug House in Delta, Utah, but he died a couple of years back. His son-in-law took over production, and even though he doesn't have Loy's many years of experience, he probably knows a few tricks. His name is Russ. I don't want to post his cell phone on line, but the store number is 435-864-2402.
Post by jakesrocks on Jul 19, 2014 11:09:02 GMT -5
I've done septarians on a disc sander, (The upright stand mounted type), using an aluminum backing plate with no padding. I used the peel off discs used for metal prep all the way to 1200 grit without water. Just work slowly so as not to overheat them. I finished them on felt with no padding and cerium oxide.
Tom
Post by Tom on Jul 19, 2014 19:46:13 GMT -5
I use my jiggle pan and have had great results. 220, 360, 600 then tin on carpet. I have not done tons of them but so far so good.
