RockOn
Member since August 2014
Post by RockOn on Aug 4, 2014 12:36:55 GMT -5
RockOn
Post by RockOn on Aug 4, 2014 12:55:46 GMT -5
RockOn
Post by RockOn on Aug 4, 2014 12:56:08 GMT -5
Wgt. 1.1 oz. 3 mm H, 2 ½ mm W, 4 mm L Non Magnetic Non conductive, Wire brush with brass dremel and turns brass in color, Wire brush with metal dremel and turns metal in color. Oxidizes quickly. Removed ½ mm Oxidized coating which had shiny exterior like cold roof tar but as tumbled became a dull surface. I wire brushed out of curiosity and the oxidized finish flaked off the nugget.
Post by Deleted on Aug 4, 2014 13:52:30 GMT -5
Bert, How heavy is this stone?.. I mean does it have any sort of weight.. as compared to other stones you might have. If you say it oxidized fast.. must be a slight hint of copper or slag of some sort.. Cause I was going to say it looks like Jet..
Post by Deleted on Aug 4, 2014 14:16:57 GMT -5
My first reaction is hematite. Though iron-based it is usually nonmagnetic/antiferromagnetic (or only very weakly magnetic) in its natural form. The "magnetic hematite" sold is usually something other than hematite.
RockOn
Post by RockOn on Aug 4, 2014 15:26:08 GMT -5
Thanks... I viewed under gemology tools Gembase and was able to find a photo of Hematite Oval Cab and Round Cab. I just may able to tumble this down to get a nice shape.
RockOn
Post by RockOn on Aug 4, 2014 15:29:18 GMT -5
Bert, How heavy is this stone?.. I mean does it have any sort of weight.. as compared to other stones you might have. If you say it oxidized fast.. must be a slight hint of copper or slag of some sort.. Cause I was going to say it looks like Jet.. 1.1 oz. I think rocks2dust may have id'ed it as hematite.
Post by radio on Aug 4, 2014 16:34:55 GMT -5
Hematite was my first thought as well. The rougher areas on it resembles botryoidal hematite to some degree
RockOn
Post by RockOn on Aug 5, 2014 13:05:05 GMT -5
Hematite was my first thought as well. The rougher areas on it resembles botryoidal hematite to some degree Thanks Radio... KA3VEC 73'S
Post by radio on Aug 5, 2014 17:34:55 GMT -5
Hematite was my first thought as well. The rougher areas on it resembles botryoidal hematite to some degree Thanks Radio... KA3VEC 73'S N6DDD formerly KI6BCC before upgrading to general I love the D104 in your QRZ pic and have 3 of them in the shack including one Silver Eagle. Is that a Swan boat anchor on the shelf? I kept an old 3 drifty around for several years and loved to play on the thing. Current setup is Kenwood TS940S and Kenwood TL 922A going into a SteppIR BigIR vertical. My fave band is 17 meters
RockOn
Post by RockOn on Aug 6, 2014 11:23:00 GMT -5
D104 for sure.. Keep it for looks as it goes well the old boat anchor. My 350 has been refurbished and when I go on line it is with PSK31 and that was last May 2013.
